Author Topic: Re-fitting Mk5 Golf 5dr front doorcards, they just wont go back on?  (Read 1713 times)
Offline Conrad The Jellyfish
any help/advice/handy tips for refitting the front doorcards, they seem to be lining up and the tweeter unit is in the way massively, is it best to just remove the tweeter unit, then slide it back on afterwards?
cheers guys
Re: Re-fitting Mk5 Golf 5dr front doorcards, they just wont go back on?
« Reply #1 on: August 12, 2011, 03:48:27 pm »
thats how did mine :happy2:
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #2 on: August 12, 2011, 04:33:06 pm »
you cant do that as you need to screw the tweeter in place with a screw under the door card.
put the window down and worry about hooking the window seal over the top of the inner door skin first, once you have this right the door card will be hanging nicely off then go round and slowly press the pop in plugs back in down every side, next do the screw and the front (normally hidden when the door is shut) this will need a lift from the base at the front to get the screw to line up.
