Author Topic: S3 rears  (Read 1988 times)
Offline MaverickFSI
  • Tornado Red Ed30 DSG
S3 rears
« on: August 14, 2011, 02:21:42 pm »
Hi guys,
Can someone give me a definitive guide to acquiring all parts required & installation for an S3 rear set up please? They will be going on an Ed30.
Many thanks.
Great balls of fire!
Retro Dubs on the go;
'91 Corrado 20vT - Project still going... and going...
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: S3 rears
« Reply #1 on: August 14, 2011, 02:33:25 pm »
Calipers, carriers, 310mm discs and pads  :happy2:
Brake lines and handbrake cables can be reused.
Offline MaverickFSI
Re: S3 rears
« Reply #2 on: August 14, 2011, 02:42:07 pm »
Cheers Steve  :happy2:
I assume these bolt straight up then? Also, what age of S3 are we looking at?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: S3 rears
« Reply #3 on: August 14, 2011, 02:46:26 pm »
Yes straight bolt on, just bend the existing dust shields back to fit the wider disc.
Your looking for ones from the 8P S3 (2006 onwards IIRC) or Mk5 R32.
Offline MaverickFSI
Re: S3 rears
« Reply #4 on: August 14, 2011, 03:20:46 pm »
Cheers bud  :happy2:
Newb question, but what does IIRC stand for?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: S3 rears
« Reply #5 on: August 14, 2011, 03:27:31 pm »
IIRC = If I remember correctly  :happy2:
Offline MaverickFSI
Re: S3 rears
« Reply #6 on: August 14, 2011, 03:41:30 pm »
Arr, right you are! Thanks again for the info mate, much appreciated  :happy2:
Offline Bikerz
Re: S3 rears
« Reply #7 on: October 21, 2011, 10:30:14 pm »
Will the 310's on rear fit behind 17's?
Re: S3 rears
« Reply #8 on: October 21, 2011, 10:48:40 pm »
The gti fronts are 312mm and accommodate 17" rims as standard.
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
Re: S3 rears
« Reply #9 on: October 22, 2011, 01:57:12 am »
REAR CII41 (Passat, Golf R32/R, Scirocco R, A3 3.2/S3/RS3, TT/TT-RS etc.):
* 4* N 910 815 01 - Innenvielzahnschraube (90Nm + 90°)
* 1* 5N0 615 611 E (1Q0 615 611 B) - Abdeckblech links
* 1* 5N0 615 612 E (1Q0 615 612 B) - Abdeckblech rechts
* 8* N 910 733 01 - Flachkopf-Torxschraube M6*12 (12Nm)
* 2* 1K0 615 601 N - Bremsscheibe innenbelüftet – 310mm*22 mm
* 2* N 106 483 01 – Senkkopf-Torxschraube (4Nm)
* 1* 1K0 698 451 K - Bremsbelagsatz mit Halteblechen
* 1* 1K0 615 425 T (1K0 615 425 R) - Bremsträger mit Führungsbolzen links
* 1* 1K0 615 426 H (1K0 615 426 G) - Bremsträger mit Führungsbolzen rechts
* 1* 1K0 615 423 G (8J0 615 423 E) - Bremssattel links
* 1* 1K0 615 424 G (8J0 615 424 E) - Bremssattel rechts
* 4* WHT 003 250 - Sechskantschraube selbstsichernd (35Nm)
silver or (black) (R)
"You get what you pay for."
