Author Topic: Coilovers - Manual & DSG versions. Do they matter?  (Read 6192 times)
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
Re: Coilovers - Manual & DSG versions. Do they matter?
« Reply #15 on: August 17, 2011, 05:42:18 am »
sorry i was bored  :signLOL:
Really!?!? I'd never have guessed  :grin: :evilgrin:
Offline jaffa666
« Reply #16 on: August 17, 2011, 08:45:25 am »
The difference in the 2 cars weights is about 30kg extra for DSG Cars which is about the same as 1/4 tank of fuel.
As Ian says the differences will be negligible  :happy2:
1.) Mk5 golf Fuel tank holds 55 litres
2.) 1/4 fuel tank = 13.75 litres
3.) 1 litre of petrol weighs 0.737 kg (petrol is less dense than water where 1 litre roughly weighs 1 kg)
4.) therefore 1/4 tank of petrol weighs 10.13kg
5.) 30kg of petrol = 40.7 litres
6.) therefore 30kg would be the weight of approx 3/4 full petrol tank  :happy2:
Didn't know rainman was a member on here  :signLOL:
Back on topic though, your best bet would prob be just to wait for a set of coilys for the dsg to come up. that way you know you cant really go wrong.
Offline ni-coilovers.co.uk
    • stores.ebay.co.uk/ni-coilovers
« Reply #17 on: August 17, 2011, 12:22:58 pm »
Realistically you wont notice unless your doing the ring and trying to get the last 10th of a second out of it.  At that just hit the gym for a few month, lose the spare wheel and run light on fuel.  If you had both side by side fitted to identical cars you prob wont notice.  Im sure the difference in 5dr to 3dr cars is 30kg or more!!
Offline RacerMH
    • MH Racing
« Reply #18 on: August 17, 2011, 12:44:47 pm »
We're not talking 'just' 30kg though. It's 30kg directly over the front axle. It may not sound like a great deal, but the car is setup to deal with varying weights in between the axles and over the rear, not over the front. It will likely make a noticeable difference in my opinion.
Adding that amount so far forward does change the dynamics of the car. Not only will it change the weight distribution significantly, but it'll also change the polar moment which affects things like turn and and under/oversteer characteristics.
Adding 30kg on the front axle will alter the distribution from 41:59 to 42:58. 1% doesn't sound much, but it does in reality make a big difference which is why the DSG will have different springs to the manual. When you're developing a car, a 1% change in weight distribution would be incredibly difficult to achieve. There's not a lot in a car that weighs 30kg on it's own that can be moved around, and car batteries are fairly commonly relocated in performance cars to achieve better weight balance/polar moment....and that's only a fraction of a %.
I wouldn't say it would be unsafe, but it'll certainly not control the front of the car very well and will likely make the car more nose heavy leading to more oversteer.
2008 Black Magic Pearl 3dr Golf GTI
Offline Frenzy
  • -Receive: 29
« Reply #19 on: August 17, 2011, 10:19:01 pm »
"Rainman", having blinded Jaffa with simple maths  :P :signLOL: agrees with this, but i think it has more relevance if you are going racing. A 1% weight distribution change would have a negligble effect under normal road driving behaviour. However if you give it a good thrash on a country road you may notice a tendency for greater understeer due to weight over front axle + non optimised springs and a windscreen full of hedge  :laugh:
Rainman also agrees with Jaffa's advice :wink:
« Last Edit: August 17, 2011, 10:21:37 pm by Frenzy »
« Reply #20 on: August 17, 2011, 10:22:49 pm »
There was me thinking the only difference was the spring rates.  :chicken:
« Reply #21 on: August 17, 2011, 10:34:02 pm »
I reckon we have had about 5 or 6 of our members including my old set of DSG Kw V2's that have gone on Manual cars and not one has posted up any problems with set up or control. I would say this speaks for it's self.  :happy2:
Offline Frenzy
  • -Receive: 29
« Reply #22 on: August 18, 2011, 12:09:23 am »
but that's DSG springs to manual, not the other way around?
You're probably right either way, as i said unless you are racing the thing fairly seriously i doubt it would have that great an affect.
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #23 on: August 18, 2011, 09:25:30 am »
I'm quite sure that the spring rate of the manual version will have a tolerance of at least 30kg. Otherwise how would anyone drive the car? When manufacturers calculate for people in the car they work off a 75kg driver usually. Well I weigh 95kg so there is an extra 20kg which would be going over the front axle more than the rear as I sit closer to the front suspenders than the rear by a good half a meter.
As has been said throughout this thread unless your on a track I would think it would be fine. I have also been in Ian's car and that feels perfectly fine with non DSG Suspension on a DSG car :happy2:
Offline PDT
  • -Receive: 142
« Reply #24 on: August 18, 2011, 10:17:53 am »
I think the end result will be massively affected by the choice of kit. It will also come down to the drivers perception of what makes a good suspension setup, I get people coming in raving about how good their Ebay £150 coilovers are and how they have transformed the handling. I drive it and its shockingly bad, crashy, tramlines, bumpsteers, knocks etc....
The DSG kit on a manual car will be OK, but from my experience, not the other way round. In any case, why bother fitting the wrong parts  :confused:
« Reply #25 on: August 18, 2011, 10:33:06 am »
75kg driver.  :signLOL:
