Author Topic: Cruise Control fitting guide  (Read 47428 times)
Offline vRS_Pagey
  • -Receive: 59
Re: Cruise Control fitting guide
« Reply #15 on: November 10, 2011, 01:52:27 pm »
then you have to do the activation code in the engine module.
I notice from your guide the number you input was '11463' is that a generic number, or if mine will be different how will I find the activation code I need?
Offline jedi-knight83
  • -Receive: 41
« Reply #16 on: November 10, 2011, 01:54:48 pm »
I got that from the rosstech site and i believe its generic.
Offline vRS_Pagey
  • -Receive: 59
« Reply #17 on: November 10, 2011, 02:11:30 pm »
Talking to a complete novice here, can you add a link?   :drinking:
Edit:  Is this it? http://wiki.ross-tech.com/wiki/index.php/Cruise_Control_Retrofitting_(1K)
« Last Edit: November 10, 2011, 02:14:01 pm by vRS_Pagey »
  • -Receive: 41
« Reply #18 on: November 10, 2011, 02:31:17 pm »
I got the code from here and also confirmed with a couple of other forum people that had done the install
http://wiki.ross-tech.com/wiki/index.php/Checking_Cruise_Control_using_Measuring_Values
Offline vRS_Pagey
  • -Receive: 59
« Reply #19 on: November 10, 2011, 02:41:27 pm »
Yup, thats the page I tried to link, but it didn't work.  :happy2:
Offline vRS_Pagey
  • -Receive: 59
« Reply #20 on: November 11, 2011, 08:27:52 am »
I'm a bit baffled mate, I am getting the cc coded today but to save a wasted journey I thought I would just confirm which module I have, a quick check and the part number ends with BC, cross checking on Ross Tech and this shows its for a midline, but mine has the highline fitted...... :confused:
Also what model year is your Caddy?  My car is an 07 so do you think the diagnostic wire will be on it?  I know I can check but it would mean taking off the wheel again and I haven't got the time.
Cheers, Lee.
Offline vRS_Pagey
  • -Receive: 59
« Reply #21 on: November 11, 2011, 04:13:55 pm »
So I paid Martin (Gizmo68) a visit today for the necessary coding, but left there slightly despondent (to begin with)!  As I mentioned in the previous post after checking the part number for my control module I was baffled to find it is listed as a midline, when I have the highline MFD.   Anyway, coding was done, first piece of good news, it has got the diagnostic cable fitted, codes were excepted so we took it for a run.........no CC??  Went back and tried again and realised the coding was wrong, input the correct ones and went out again, still no CC, went back and decided to have a search on the Ross Tech site for anything we missed then Martin found the following:
1K0-953-549-BC    Type 2    SW 0070    Midline    Yes    -    #1
Above is the part number for my control module and the '#1' at the end means that CC can not be retro fitted!!  :sad1:  Bear in mind there are about 40 different variations and mine is the only one that doesn't work....... :sick:
Anyway,  we decided to leave the coding in place in anticipation of me sourcing an new controller.  On the drive home I turned on the CC for some reason at which point the light illuminated on the dash board and hey presto, I now have CC?????????????
Very baffled, but not complaining, I will still keep an eye out for a new control module though as mine definitely doesn't support a MFSW.
« Last Edit: November 11, 2011, 07:02:03 pm by vRS_Pagey »
  • -Receive: 41
« Reply #22 on: November 11, 2011, 04:51:07 pm »
Thats odd about the #1 designation... I must admit i'd never noticed that but also then odd that its decided to work...
Sorry for the late reply.. been at work but as you found out you do have the diagnostics wire... My understanding is that its already on any car after 06.
Also re midline / highline... I dont think that relates to if you have a highline dash or not... Its just the 3 grades of steering control module.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #23 on: November 11, 2011, 06:30:17 pm »
I have fitted cruise control to 2 cars with the BC controller
1st didn't work ( 638 SW 0070 )
2nd worked ( 035 SW 0070 )
Cluster and Key coding
Location Great Yarmouth
Offline gizmo68
  • We're here for a good time, not a long time
« Reply #24 on: November 11, 2011, 06:49:06 pm »
Ross-Tech claim:
Control Module Part Number    Slip Ring      Software Level    Variant    Steering Angle Sensor    LIN Version    Notes
    Notes:
        #1: Does NOT allow Cruise Control Retrofitting, in such a Case you need to replace the Steering Wheel Control Module.
This is the scan from Lee's controller:
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BC    HW: 1K0 953 549 BC
   Component: Lenksäulenmodul 036 0070
   Coding: 0000012
   Shop #: WSC 01279 785 00200
   VCID: 74EC69276E20
« Last Edit: November 11, 2011, 06:53:30 pm by gizmo68 »
VCDS HEX-NET & VCP owner (covers all VAG cars)
(PM me if you require VCDS or VCP coding or scanning in Kent)
Offline vRS_Pagey
  • -Receive: 59
« Reply #25 on: November 11, 2011, 06:58:20 pm »
I thought so??  No worries about the late reply, I wasn't expecting you to be at my beck and call....... :P  I see what you mean about the low/mid/highline, mine is a midline as it doesn't have a MFSW.
Interesting, what significance does the '638' and '035' number have, I can't seem to find them codes in Ross Tech wiki?
Ross-Tech claim:
    Notes:
   Coding: 0000012
   VCID: 74EC69276E20
Many thanks for the time spent today, especially now as I have the desired result, enjoy the black stuff!  :notworthy:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #26 on: November 11, 2011, 07:01:32 pm »
638 & 035 or 036 on your one is the Hardware version
so low hardware works maybe????
Offline liver
« Reply #27 on: November 11, 2011, 07:09:50 pm »
   Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
   Component: Lenksäulenmodul 634 0070
   Coding: 0000012
   VCID: 76E7837A78B5
No fault code found.
this is mine, does this mean i would need to change the control module to get cruise control fitted?/
Offline vRS_Pagey
  • -Receive: 59
« Reply #28 on: November 11, 2011, 07:12:41 pm »
   Coding: 0000012
   VCID: 76E7837A78B5
Based on Eddie's observations I would think probably yes.   :sad1:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #29 on: November 11, 2011, 07:20:10 pm »
   Coding: 0000012
   VCID: 76E7837A78B5
Yours will be ok as it ends AF the problem one ends BC
