Author Topic: Cruise Control fitting guide  (Read 60910 times)
Offline jedi-knight83
  • -Receive: 41
Re: Cruise Control fitting guide
« Reply #45 on: November 14, 2011, 12:04:59 am »
i have a 55 plate , i only needed the stalk if this help  :jumping:
My van was 55 but was technically an early 06 build so had the wire. Some 55 plates do have it.
MPS
« Reply #46 on: November 14, 2011, 09:03:57 am »
My 55 plate 06MY gti had the wire too.
Offline vRS_Pagey
  • -Receive: 59
« Reply #47 on: November 16, 2011, 05:42:40 pm »
I'm well happy with the retro fit in the Golf, I am now thinking about it for the vRS.  Can someone confirm if the stalk will be the same?  Hopefully it will have the wire, it's a 56 plate, but to be on the safe side I think I will physically check this first.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #48 on: November 16, 2011, 05:43:21 pm »
I'm sure it has the wire and it is the same stalk
Cluster and Key coding
Location Great Yarmouth
Offline vRS_Pagey
  • -Receive: 59
« Reply #49 on: November 17, 2011, 02:01:48 pm »
That's good news then, I will just need to confirm the steering control module part number then I will get on eBay.  :happy2:
Edit:  Just checked the vRS and it has the 'BC' control module, the same as in the Golf.  So 50/50 chance it will work!   :popcornsoda:
« Last Edit: November 17, 2011, 02:16:32 pm by vRS_Pagey »
Offline SeanB
« Reply #50 on: January 31, 2012, 07:59:00 pm »
If anyone's in Staffs and wants this fitting to their car I'll do it for some beer tokens as I did mine at the weekend and now I know what I'm doing it's a doddle.
Hi Mate,
I'm in Stourbridge and have just bought a stalk, if you have VC to program it and can fit it, I will happily supply beer tokens (and Beer)!!
I would send a PM, if I had posted on here enough to be allowed to send PM's Doh!
Offline Meallbhan
« Reply #51 on: February 21, 2012, 11:15:57 pm »
When the cruise control is all fitted and working, do you get a light on the dash to tell you when its turned on?  One of the works pool cars is an Octavia and has a wee green dial illuminates above the rev counter to tell you.
Offline mad_pete
« Reply #52 on: February 21, 2012, 11:28:10 pm »
yep exactly that
Offline Meallbhan
« Reply #53 on: February 22, 2012, 07:37:21 pm »
So the car already has the light fitted, not used, but ready to be?
Offline mad_pete
« Reply #54 on: February 23, 2012, 12:37:38 am »
Yep, standard display pod I guess
Offline vRS_Pagey
  • -Receive: 59
« Reply #55 on: February 25, 2012, 06:43:31 pm »
Reviving this thread as Martin completed a diagnostic on the vRS today.  Looking at the info for the steering controller we discovered that it is almost identical to the Golf -
vRS:
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BC    HW: 1K0 953 549 BC
   Component: Lenksäulenmodul 036 0070
   Coding: 0000012
   Shop #: WSC 73430 790 00000
   VCID: 74EC692717A00E3
Golf:
   Coding: 0000012
   Shop #: WSC 01279 785 00200
   VCID: 74EC69276E20
As you can see the differences are in the last two lines - Shop # and VCID.  Can anyone in the know, tell what these relate to and if they will cause an issue fitting cc?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #56 on: February 25, 2012, 06:55:40 pm »
I'm not sure what VCID is but the shop number simply relates to the dealership, factory or bench.
WSC = Workshop Code
Stu...
Offline vRS_Pagey
  • -Receive: 59
« Reply #57 on: February 25, 2012, 07:05:05 pm »
Just browsing google and one possiblity could be VCID - Virtual Circuit Identification?
Offline Turbosteve
« Reply #58 on: February 26, 2012, 06:38:18 pm »
Anyone in south Yorkshire that could fit cruise control to my 11 plate caddy please... And if poss to my 10 plate T5.1 transporter ..... Vw want silly money for both vehicles and I have not got a clue....
Steve
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #59 on: February 26, 2012, 06:54:34 pm »
The caddy probably has the newer type combination stalks
the transporter probably can be done, but needs a loom to be fitted
