Author Topic: Rear windows  (Read 1693 times)
Offline WYTHIT
Rear windows
« on: August 16, 2011, 07:09:48 pm »
Hi guys another problem appeared with my mk5 gti 5door today the rear windows won't wind down first  I checked the30amp fuse it was fine but still changed it for a new fuse.It still didn't work.The front windows are working fine I checked all the rear switches to see if just one of them worked no joy.I took the fuse out of the front windows to see if can hear the switch engaging it sounds fine but the rear window switch you can't hear anything.please help
« Last Edit: August 17, 2011, 09:54:30 am by WYTHIT »
Offline WYTHIT
Re: Rear windows
« Reply #1 on: August 17, 2011, 09:54:58 am »
Can anybody help  :surprised:
Offline WYTHIT
Re: Rear windows
« Reply #2 on: August 17, 2011, 10:47:47 am »
I'm sure the master switch has broke so I've ordered a knew on off ebay
Offline WYTHIT
Re: Rear windows
« Reply #3 on: August 19, 2011, 02:43:02 pm »
I've changed the switch today and the rear windows still don't work :ashamed:
Has anybody off here ad the same problem?please help
Offline WYTHIT
Re: Rear windows
« Reply #4 on: August 19, 2011, 04:57:17 pm »
 :sad1:
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
Re: Rear windows
« Reply #5 on: August 20, 2011, 07:14:26 am »
Break in the wire?. Check in the rubber sleeve/gromit in the door opening. :smiley:
Offline edd666999
  • -Receive: 89
Re: Rear windows
« Reply #6 on: August 20, 2011, 08:13:03 am »
get the car scanned for errors?
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
Re: Rear windows
« Reply #7 on: August 20, 2011, 09:25:28 am »
You need a VCDS scan. Check the VCDS sticky for someone in your area.
http://www.mk5golfgti.co.uk/forum/index.php/topic,120.0.html
