Author Topic: GT TDI Starting  (Read 12087 times)
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
Re: GT TDI Starting
« Reply #15 on: January 11, 2012, 08:17:37 pm »
It was my camshaft positional sensor that was faulty which was causing mine, VW replaced it under warranty!  :happy2:
Offline Richie18-1987
Re: GT TDI Starting
« Reply #16 on: January 25, 2012, 12:28:47 am »
Have you checked the cam sensor and the crank sensor as they can cause a delay in starting as the ecu will need a reading from both of them at exactualy the same time before the engine will fire up might be worth getting somebody on this forum with vag com to check it over for you because if one of them is not doing its job properly that will cause your problem hope this helps.
