Author Topic: Water meth- does anyone run it?  (Read 2837 times)
Offline martziniuk
« on: August 18, 2011, 05:44:12 pm »
I'm finding myself getting getting more and more tempted by the benefits of running a water methanol kit. Does anyone on here run one as I've not seen any posts lately and what do you think for everyday driving?
Re: Water meth- does anyone run it?
« Reply #1 on: August 18, 2011, 05:58:19 pm »
I bought a Labonte S4 kit but ended up not fitting.  Partly because of lack of known / trusted tuners where I am in Germany and also Im not 100% happy with my software as it is, dont want to further complicate things, rather just go for new Mapping 1st.  The Apr I have isnt adjustable either to help map to the W/Meth kit
Revo would be well suited to a W/Meth kit
Offline martziniuk
« Reply #2 on: August 18, 2011, 07:45:52 pm »
Sell me it  :drinking:
I would run it with the Stage 2+ map and would not get the map changed for it. I would be just happy to run lower octane fuel and take advantage of lower intake temps and possibly better mpg.
« Reply #3 on: August 18, 2011, 07:57:57 pm »
Sold it a bit back back mate sorry
Offline martziniuk
« Reply #4 on: August 18, 2011, 08:03:10 pm »
No probs  :happy2:. Anyone else fitted one?
« Reply #5 on: August 18, 2011, 08:07:35 pm »
I think there is a long term issue with wm in our engines as it seems to cause premature failure of the throttle body motor depending on where abouts you spray the meth.
« Reply #6 on: August 18, 2011, 08:12:55 pm »
I can't remember who I sold it to but I'd be interested in seeing the results
Offline martziniuk
« Reply #7 on: August 18, 2011, 08:32:30 pm »
Yeah I had read that happened in one case, something to do with a plastic throttle slide.
Offline Cupra R
  • -Given: 18
« Reply #8 on: August 19, 2011, 04:02:10 pm »
Yep, but if it is injected after, either by direct port or using one of the Throttle/manifold adaptor plates, then the issue should be resolved.
Apparently  :signLOL:
« Last Edit: August 19, 2011, 07:21:33 pm by Cupra R »
Offline martziniuk
« Reply #9 on: August 19, 2011, 07:08:38 pm »
Hmm I'll look into that but it sounds more complicated and expensive  :scared:
« Reply #10 on: August 19, 2011, 07:14:39 pm »
The bsh throttle body pipe is one ready-made solution.
http://www.bshspeedshop.com/bshstore/products/BSH-FSI-Integrated-Throttle-Pipe.html
Offline Cupra R
  • -Given: 18
« Reply #11 on: August 19, 2011, 07:20:11 pm »
This would still pass the Butterfly valve though in the throttle body
Offline Cupra R
  • -Given: 18
« Reply #12 on: August 19, 2011, 07:22:58 pm »
Not more complicated to be honest.  Seen them for about $70-80
« Reply #13 on: August 19, 2011, 07:25:29 pm »
Yup but the only way to bypass the butterfly flap is to drill port(s) for the injector(s) in the intake manifold itself.
Offline Cupra R
  • -Given: 18
« Reply #14 on: August 19, 2011, 08:09:37 pm »
Can use one of these.
http://www.usrallyteam.com/images/wai_tbflange_fsi.jpg
