As a slight aside, should your alignment centre leave the car with imbalance on the front caster or camber and you really want to get the car spot on, it can be "optimised". I did my car a few month's ago on a dynamic computerised rig, and by moving the sub-frame around, you can balance it across the axle. For a mildly sporty hatch, the mk5 is quite sensitive to the geometry.
