Author Topic: ESP  (Read 2164 times)
Offline jamma
ESP
« on: August 23, 2011, 03:28:58 pm »
Quick question, what is ESP? Is it some sort of  traction control? I have never switched it off , what will happen when I do?
Having 2 new tyres fitted Thursday so need to wear my fronts out a bit more so this may help lol
  • -Receive: 291
Re: ESP
« Reply #1 on: August 23, 2011, 03:33:51 pm »
"electronic stability control" - yes, essentially traction control. Applies the brakes to the wheels that are just spinning. Do a launch from a standing start with it on and off, then go around a corner fairly briskly with it on/off.
Offline Frenzy
  • -Receive: 29
Re: ESP
« Reply #2 on: August 24, 2011, 09:52:07 pm »
ESP - is Electronic Stability Programme and incorporates traction control (stops too much power going to the driving wheels when under acceleration) and ASM - Automatic Stability Management into one package. ASM is when the on board computer senses that one or more wheels are losing grip and as a result will cut power and apply ABS braking to the wheel in question until grip is re-established.
Go round a tight roundabout and keep accelerating as you go round and round, eventually your tyres will loose grip (crap tyres sooner than good ones) and as it happens ESP will kick in*  :laugh:
* I don't really advise doing this, trust me what i describe will happen, but if you wanna try it you do so at your own risk  :signLOL:
Offline RacerMH
    • MH Racing
Re: ESP
« Reply #3 on: August 25, 2011, 08:38:30 pm »
I should be able to answer this one for you as I tune the systems for my job ;)
ESP (Electronic Stability Programme) or DSC or any of it's other acronyms is a 'Stability Control System' that incorporates the functions of Traction Control and ABS, EBS (Electronic Brake force Distribution) and Corner Brake Control to help the driver maintain control during an emergency manoeuvre or when there's a sudden change in grip level or when the ABS controller senses the car has lost stability (entering a skid)
Things it can do are:
-Prevent massive wheel spin during acceleration
-Prevent the wheels locking under braking
-Kill under and oversteer before it develops in to something more serious
-React quicker than any driver in an emergency situation (e.g. a high speed lane change to avoid someone pulling out in front of you).
Things it can't do are:
-Stop you crashing
-Brake to an appropriate speed for a corner.
-Pre-empt what's going to happen next. It needs a degree of wheel slip or a level of lateral acceleration/steering angle before it can react. It effectively 'catches' the car.
Providing you've slowed down for the corner in the first place, it should be virtually impossible to spin or understeer off the road. If you feel happy doing so, find yourself a deserted wet roundabout and build your speed up gradually. When the front wheels start to slip wide, the ESP will apply the inside rear brake to pull the nose back in. If you repeat this and then lift off, the car will start to oversteer, however, the ESP will brake the outside front wheel to stabilise the car. You'll hear a coarse noise a bit like a rake being dragged through gravel (honestly the best way I can describe it) which is the ABS pump running and generating pressure to apply individual brakes. The ESP light will then flash 3 times or more depending on the length of the intervention.
These days ESP systems are incredibly complicated and take a great deal of time to calibrate. Just to give you an idea.....the current Bosch ESP controller has around 20-30,000 parameters that can/must be tuned for each car!
« Last Edit: August 25, 2011, 08:40:10 pm by RacerMH »
2008 Black Magic Pearl 3dr Golf GTI
Offline jamma
Re: ESP
« Reply #4 on: August 26, 2011, 08:49:35 am »
-Stop you crashing
Thanks for the write up , similiar to my previous car which has PSM but this was for all 4 wheels. I assume this is just the fronts?
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
Re: ESP
« Reply #5 on: August 26, 2011, 09:32:48 am »
Nope, not just the fronts. As Racer said: "When the front wheels start to slip wide, the ESP will apply the inside rear brake"
Offline Frenzy
  • -Receive: 29
Re: ESP
« Reply #6 on: August 26, 2011, 09:35:10 am »
Hey, i said the same just with less words and detail!  :signLOL:
Offline jamma
Re: ESP
« Reply #7 on: August 26, 2011, 09:55:55 am »
Yes thank you too  :signLOL:
Offline Frenzy
  • -Receive: 29
Re: ESP
« Reply #8 on: August 26, 2011, 09:58:08 am »
you're welcome  :grin:
Offline swgti
  • -Given: 28
Re: ESP
« Reply #9 on: August 26, 2011, 07:36:34 pm »
:confused:
Offline golf nutter
  • -Given: 19
Re: ESP
« Reply #10 on: August 26, 2011, 07:54:52 pm »
excellent write up! thanks.
