Author Topic: URGENT - keys locked in car  (Read 4605 times)
Re: URGENT - keys locked in car
« Reply #15 on: August 25, 2011, 10:11:31 am »
You can also lock it with the boot open and could toss the keys in there if that was your bag. Same for the rear doors.
Need one of these if you are in a hurry.
 :wink:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=c734golhlj0ltskbc9f0et8ccc&/topic,19740.0.html
« Reply #16 on: August 25, 2011, 10:24:22 am »
These mk5s are literally impenetrable. I did the same thing a while back, and the only reason why we could get in (after 1.5 hrs of trying every known trick) was because the passenger window was down sufficiently to allow a metal rod to be passed through it and into the boot!
Offline gulfstream11
« Reply #17 on: August 25, 2011, 12:48:04 pm »
If you use the boot unlock button it's quite easy to lock the keys in the boot, as only the boot latch is released. The other doors remain locked, plus the boot locks automatically once shut again. That's why i only ever use this button when I'm at home & have access to the spares.
I will use the boot release button but I'll put the keys into my pocket so there's no danger of them being accidentally locked in the boot.
That is how it happened, i used the boot release botton and shut the boot.
Ahhhhhh... You see I said I had no idea... In my nearly 3.5yrs of MK5 ownership I have never used the boot unlock feature. :chicken:
Cheers all
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
« Reply #18 on: August 25, 2011, 01:16:54 pm »
Safest way, Gulf :laugh:
