Author Topic: Boost issues??  (Read 892 times)
Offline chris s
Boost issues??
« on: August 28, 2011, 02:01:48 pm »
Can anyone tell me if these results imply a boost leak or an issue with theN75 valve?
'115
Engine Speed   Engine Load   Boost Pressure   Boost Pressure
      (specified)
 /min    %    mbar    mbar
1640   106   1620   1330
1600   106.8   1610   1330
1640   106.8   1620   1340
1640   108.3   1620   1340
1640   107.5   1620   1350
1640   108.3   1640   1350
1920   107.5   1950   1380
2160   113.5   2220   1440
2400   124.1   2400   1560
2640   136.1   2420   1730
2920   154.9   2310   1970
3080   186.5   2360   2330
3400   191.7   2300   2510
3640   191.7   2260   2470
3840   185.7   2250   2270
4040   177.4   2260   2210
4280   176.7   2290   2210
4560   181.2   2320   2230
4800   180.5   2350   2250
5040   178.9   2400   2300
5280   181.2   2410   2330
5480   181.2   2360   2340
5720   181.2   2330   2310
5960   176.7   2230   2260
6160   171.4   2240   2240
6320   167.7   2210   2180
Candy White Edition 30 DSG
Revo Stage 2+
ITG, BCS TBE, Autotech HPFP
WALK
R32 Brake upgrade
S3 IC upgrade
Re: Boost issues??
« Reply #1 on: August 28, 2011, 03:06:40 pm »
You are making requested and exceeding boost at times but that doesn't exclude a small leak.
Try logging block 118 for your wastegate (N75) Duty Cycle and post the result.
btw this should be in the vcds forum.
Offline R-tech-Nick
  • -Receive: 30
    • R-Tech Performance Tuning
Re: Boost issues??
« Reply #2 on: August 28, 2011, 03:22:42 pm »
As these engines don't have boost maps as such, the best blocks to log would be 114 engine load spec and actual along with the n75 duty.
Post the 114 log up and I will try and help
Nick
01455 617233
Offline chris s
Re: Boost issues??
« Reply #3 on: August 28, 2011, 06:15:15 pm »
Cheers mate - I'll get this data logged when I have the REVO map put back on :happy2:
Revo Stage 2+
WALK
R32 Brake upgrade
S3 IC upgrade
