Author Topic: retrofit PTC heater from TDI models  (Read 7645 times)
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« on: August 29, 2011, 03:59:09 pm »
Found this:
1K0963235E Heizelement 305,83€
1K1998250 Leitungssatz für PTC 51,11€
1K1819349E Abdeckung 8,45€
1K0972704C Flachkontaktgehäuse 0,32€
000979009E Einzelleitung (can-bus) 2,32€
N10118105 Bundmutter M5 0,64€
1K0919625 Bundschraube 0,13€
N10525506 Sicherung 100A 2,14€
GTIs should have the same 140 A alternator as the TDI models.
So not an issue at all. Required labour is two to three hours.
If you like it warm in the winter time.  :wink:
« Last Edit: September 01, 2011, 12:14:32 pm by the bruce »
"You get what you pay for."
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: retrofit PTC heater from TDI models
« Reply #1 on: August 29, 2011, 04:41:42 pm »
Cluster and Key coding
Location Great Yarmouth
Offline vwdubster77
« Reply #2 on: August 29, 2011, 04:48:52 pm »
Is this for 1 cable or a set, ie 2 cables.
As 1Q0 971 478 A/B is the wiring harness for this heater, I guess its HIGH Amp cable. at twice the price of the above.
I was looking into doing this on my Tdi, but then read reports that there was also a fire issue, due to a bad earth, which caused over heating.
I pulled all the drivers side trims off looking on where this is to be fitted, couldn't find the slot in the HVAC. Couldn't make sense of the diagram.  :sad1:
« Last Edit: August 29, 2011, 04:54:14 pm by vwdubster77 »
« Reply #3 on: August 29, 2011, 06:27:09 pm »
What's this?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #4 on: August 29, 2011, 06:40:05 pm »
What's this?
its an electric heater which is a nice feature in the winter. Starts giving of heat after 30 seconds. All soot chuckers have them
« Reply #5 on: August 29, 2011, 06:43:39 pm »
Everything in the 1st link above needed? A pricey mod. Will get another remap and wear an extra T -shirt  :grin:
Loving all the retro fits and oem upgrades on this site though, sensible purposeful modifying  :happy2:
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #6 on: August 29, 2011, 07:05:10 pm »
You know this forum is expensive !!  :laugh:
« Reply #7 on: August 29, 2011, 07:12:37 pm »
Tell me about it!  :fighting:
 :signLOL:
Offline vwdubster77
« Reply #8 on: August 29, 2011, 07:14:58 pm »
What's this?
Mine don't  :sad1:
MPS
« Reply #9 on: August 29, 2011, 08:22:20 pm »
What's this?
Mine don't  :sad1:
AFAIK, this option was only usually available / fitted in cold climate countries i.e. Sweden, Norway, Finland, etc.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #10 on: August 29, 2011, 09:27:59 pm »
Every TDi that I have scanned with my Vag-com in the UK has had one
7D - Auxilary PTC-Heater
The rarer one is Address 18 - Auxilary Heating (Webasto Heater)
Offline vwdubster77
« Reply #11 on: August 29, 2011, 09:50:12 pm »
Mine don't :booty: its even unchecked in VCDS, followed that link where the guy retro fitted the heater, I don't have the fuse either. Hence the reason I went looking for it.
Any other checks would be welcome.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #12 on: August 29, 2011, 10:01:42 pm »
weird,
is your car a UK supplied car?
if it is what year is it?
Offline vwdubster77
« Reply #13 on: August 29, 2011, 10:09:00 pm »
Yup, UK supplied.
Registered July 07
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #14 on: August 29, 2011, 10:17:40 pm »
Yup, UK supplied.
Registered July 07
who else hasn't got one fitted.
newest TDI I have scanned is an 06 and it has one
Passat 11 plate doesn't have one
