Author Topic: Revo removed?  (Read 1618 times)
Offline Ducky76
Revo removed?
« on: August 29, 2011, 08:38:39 pm »
Hi I've just bought a 05 gti 2 month ago and on some paper work for a misfire problem 2/3 year ago it says revo software found but the car don't feel like any thing more than normal could some one have disabled it cos I was thinking of having a remap any way 2 ree do it by my self , prob a daft question ??
Cheers andy
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: Revo removed?
« Reply #1 on: August 29, 2011, 08:40:16 pm »
It could have been put into stock mode, so can easily be re-enabled with a Revo select / select plus switch  :happy2:
Re: Revo removed?
« Reply #2 on: August 29, 2011, 08:43:49 pm »
Battery disconnection can reset to 0 0 0 settings as mentioned can be re applied using REVO handset
Offline Ducky76
Re: Revo removed?
« Reply #3 on: August 29, 2011, 08:59:17 pm »
Ok then, I was going 2 get remaped at jbs on Friday cos it's local but thinking now I could just rolling roaded check every thing is ok with the Dv cos the other day my mate in vrs fabia was getting away from me up hill thou 130 diesel And that shouldn't  happen even standard should it??
Offline Poppa Dom
Re: Revo removed?
« Reply #4 on: August 29, 2011, 09:43:50 pm »
Where are you based as there may be someone local to you with a Revo switch :)
Offline Ducky76
Re: Revo removed?
« Reply #5 on: August 29, 2011, 09:59:14 pm »
In Chesterfield mate think il just rolling road it if dv faulty get them 2 change it then I'm going 2 edition 38 at weekend so il have a word with revo there would be a waste if revo already installed see about switch , don't realy know any one on here
Cheers  andy
Re: Revo removed?
« Reply #6 on: August 29, 2011, 10:03:38 pm »
Hurdy is Sheffield and has a REVO handset, he used to frequent Nobles RR which is in your area
