Author Topic: Constant steering adjustments whilst driving in a straight line.  (Read 1976 times)
Offline Black9
  • -Given: 35
« on: September 01, 2011, 04:57:48 pm »
Does anyone else have to make them, just had my 4 wheel alignment done and have found after, I need to make small adjustments even on straight roads. I know every road has a slight off camber but is this normal? The steering itself seems ok but the constant adjustments are getting a bit annoying. The car has 18" Monza wheels and 4 new tyres too!
The front tyres are Vreds and according to the guy who done the alignment they're known for causing cars to pull due to their tread design :scared:
Offline Boothy
Re: Constant steering adjustments whilst driving in a straight line.
« Reply #1 on: September 01, 2011, 05:14:59 pm »
I have the same tires and mine doesn't pull or tramline really, maybe in extreme circumstance but not usually. Certain setups can exaggerate the effect you talk of such as positive/negative camber and the wheel toeing in/out. It may be that the original set up was using these setting to reduce the wandering and the guy who has done the alignment has removed the effect by setting them up dead straight etc?
I've never had a four wheel alignment on the Golf so I'm just theorizing really but the set up definitely has an effect on stability vs cornering.
MPS
« Reply #2 on: September 01, 2011, 09:18:01 pm »
I feel I could take my hands off the wheel @ 70mph if I wanted, that's how planted my car feels!
« Reply #3 on: September 01, 2011, 09:28:17 pm »
Are all four of your tyres matched?
When I temporarily had r888 front hood year F1 rear the handling was bizzare.
Offline Black9
  • -Given: 35
« Reply #4 on: September 01, 2011, 09:57:41 pm »
My car feels quite well balanced and stable at higher speeds, I just find myself having to make small ajustments to the steering every so often.
The tyres are matched at the front, 2X Vreds Ultrac sessanta and the rear are 2 budgets(which came on the car) 2X autogrip tyres. Reason I kept the autogrip tyres are cause theyre basically brand new with loads of tread.
But the budgets are on the rear so would this make that much of a difference to the front steering inputs?
Also I drove around for 1 week plus with the Vreds when the alignment was out, could this have changed the shape of the tyre causing them to pull slightly? As the alignment machine says it can find no faults with the cars suspension. He did say he had increase or decrease the front toe angle, can't remember which :scared:
Thanks for the replies :happy2:
Offline Frenzy
  • -Receive: 29
« Reply #5 on: September 05, 2011, 11:36:38 pm »
I've got Vreds on mine, done 380 miles on them. I've never experienced the car pulling with them and i've done all kinds of driving, town, motorway and a bit of a thrash  :evilgrin:
Replaced all 4 corners in one go despite having very good tread (6mm all round), on almost new Avon ZZ3s  Why? Because otherwise i'd be mixing Syms with Asyms and that's a no-no for decent handling let alone good handling.
My hypothosis is that the budgets on the back are syms.
Just my tupence but so long as it aint directly taking food out of your kids' mouths then you shouldn't skimp on tyres - sack the budgets off, good tread or not - you can sell them on ebay and get yourself Vreds all round  :happy2:
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #6 on: September 06, 2011, 01:52:45 pm »
1. Upload the alignment sheet and post the link here.
2. Throw away the cheap rear tyres (buy Michelins for front and put Vreds to rear)
"You get what you pay for."
