Author Topic: CV joint gaiter replacement  (Read 1376 times)
Offline craig_t
  • Craig
« on: September 01, 2011, 08:24:12 pm »
This weekend I'm going to attack replacing my inner cv joint gaiter as mine has a split and grease is going everywhere :/
Has anyone else here replaced this that could tell me if it's going to be a bit of a pig to do. Luckily I have access to a car lift so I can get the car in the air.
Admin notice, sig pic removed for being to big.
WILLZIE
Re: CV joint gaiter replacement
« Reply #1 on: September 03, 2011, 11:50:44 am »
Had mine done last month, used an independent garage as the price was good, they did it in under an hour, I supplied the kit from VW which was about £22, new clips etc, they had no trouble, 2 ways of doing it i think though from the ball joint!, either undo the 3 bolts taking the ball joint out with it or seperate it!. (they seperated it) i was a bit dubious as sometimes when you seperate it you can then split the ball joint itself, giving you another bit of grease leaking out.
