Author Topic: Oil under the car!!  (Read 2289 times)
Offline baldwined30
Oil under the car!!
« on: September 03, 2011, 10:05:41 am »
Morning people!
I jacked the car up today as at some point this week i will be changing my intercooler. When i took the bottom panel off there was a small plastic can with oil all around it. Does any one know what this is? Obviously i want all problems out the way before i remove the old IC! Thanks in advance!!
Ed30
Re: Oil under the car!!
« Reply #1 on: September 03, 2011, 10:13:41 am »
Your oil filter is in there.
The cannister is made of plastic and may well have cracked causing oil leakage. If not tightened properly the same may occur.
Offline baldwined30
« Reply #2 on: September 03, 2011, 10:15:36 am »
Arrh, now it even looks like it!! Just to confirm, this is under the car! Seems like fiddling with cars is like houses, you always come across something!!
Ed30
« Reply #3 on: September 03, 2011, 10:25:00 am »
That's 100% your oil filter housing. If it's leaking you could try and nip it up but it's a good opportunity for some fresh oil  :happy2:
Offline baldwined30
« Reply #4 on: September 03, 2011, 10:38:12 am »
Mike I think your right!! There always an oppertunity to spend on these cars! Just with out telling her indoors haha
Ed30
Offline baldwined30
« Reply #5 on: September 03, 2011, 10:57:34 am »
is there a part number for this?
Ed30
« Reply #6 on: September 03, 2011, 11:00:10 am »
I've only ever had to order the inner filter element, sorry
Offline baldwined30
« Reply #7 on: September 03, 2011, 11:01:46 am »
No probs mike, i should get off my lazy arse and have a look! :happy2:
Ed30
WILLZIE
« Reply #8 on: September 03, 2011, 11:32:37 am »
Theres an orange nipple inside that cap, you can depress it to release the oil out first without unscrewing the whole canister before taking the filter out! (designed to be less messy), but your also supossed to press it again to releae it, otherwise oil will just pi$4 out!, this may of been forgotten and just the cap screwed back on!
« Reply #9 on: September 03, 2011, 11:34:45 am »
With out the super overpriced special tool to drain the housing it can still be a bit messy.
Offline baldwined30
« Reply #10 on: September 03, 2011, 11:37:51 am »
Think ill book it in with a friend who has a very good VW place in Essex! I'm guessing its ok to drive?
Ed30
« Reply #11 on: September 03, 2011, 11:54:11 am »
Make sure the oil level is ok 1st  :happy2:
Offline baldwined30
« Reply #12 on: September 03, 2011, 01:26:33 pm »
Just looked at the casing, its about 4 times the price of a filter, naturally haha!
Ed30
« Reply #13 on: September 03, 2011, 01:43:46 pm »
If you want to spend even more money then this may be of interest to you.  :smiley:
http://www.awesome-gti.co.uk/product.php?xProd=39842&xSec=151
Offline baldwined30
« Reply #14 on: September 03, 2011, 03:13:32 pm »
thats prob worth it to be fair!!
Ed30
