Author Topic: Datalogging session done  (Read 3767 times)
Offline Russ_leeds
« on: September 03, 2011, 04:57:33 pm »
A big thanks to nasir for logging my car for me :notworthy:
He's gonna post the logs up later on. I'm getting a missuer on cylinder 4
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
Offline robdf2
Re: Datalogging session done
« Reply #1 on: September 03, 2011, 07:16:07 pm »
y
Ah the old french missfire  :rolleye:
2008 Chrono yellow Cupra
« Reply #2 on: September 03, 2011, 07:20:13 pm »
Did he try swapping cylinder 4 coilpack with one of the others and re-logging your misfire count?
How much mileage on your present plugs?
« Reply #3 on: September 03, 2011, 07:22:37 pm »
TFSIs eating plugs and coilpacks for breakfast again?  :rolleye:
Offline Scousus maximus
« Reply #4 on: September 03, 2011, 07:32:11 pm »
y
Straight out of "Allo Allo", a brilliant series if ever there was one. :laugh:
Regards,
John
Offline Russ_leeds
« Reply #5 on: September 03, 2011, 07:57:27 pm »
Hahaha bloody iPhone! We took the connector of both the end coilpacks as wasn't sure which one is 1 and which is 4. When we took the leads off either 1 the car ran lumpy. It's on 56k on original plugs
« Reply #6 on: September 03, 2011, 08:06:15 pm »
Change your plugs first.  :smiley:
Nasir
« Reply #7 on: September 03, 2011, 08:13:47 pm »
Bacillus is right, I'd first swap the coilpacks around and log again.....should have thought of that :ashamed:
The plugs will need to be changed sooner rather than later as he said.
One thing to note is that the boost actual was considerably higher than requested, I put this down to it being mapped? I am about to post the scan results of the car.
Nasir
« Reply #8 on: September 03, 2011, 09:01:55 pm »
No point posting the whole thing, just 1 fault on the engine.
Address 01: Engine
1 Fault Found:
001089 - EVAP Emission Control Sys: Incorrect Flow
               P0441 - 002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 2
                    Fault Frequency: 29
                    Mileage: 81514 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 23:12:06
             Freeze Frame:
                    RPM: 758 /min
                    Load: 16.1 %
                    Speed: 0.0 km/h
                    Temperature: 87.0°C
                    Temperature: 33.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.097 V
http://wiki.ross-tech.com/wiki/index.php/16825/P0441/001089, fault frequency 29 so there is clearly a problem. However it did not return after a short run and it worked on the output test.
« Reply #9 on: September 03, 2011, 09:09:00 pm »
Looks like a fault I read about recently,
I think its the charcoal canister fault, a cause being 'brimming' the tank to the top
VrsCarl mentioned it before
Offline martziniuk
« Reply #10 on: September 03, 2011, 10:22:58 pm »
I had that fault code and replaced the charcoal canister, the fault code has never returned. This code should not affect the running of the car, it's just emmisions rubbish.
Offline Russ_leeds
« Reply #11 on: September 04, 2011, 12:32:01 am »
cheers yeah ill get some new plugs on monday and see if that sorts it :popcornsoda:
how much are charcoal canisters?
when we logged the boost the actual was miles higher than the requested i cant remember the values but i was a bit concerned by this :confused:
Nasir
« Reply #12 on: September 04, 2011, 11:09:50 am »
Yes the logs showed the boost actual was always higher than requested. I can't remember the units but it was 1000 (mBar?) even at idle when it was requesting 400mbar. I think this could be down the remap but somebody with more experience will have to comment.
Offline martziniuk
« Reply #13 on: September 04, 2011, 12:09:19 pm »
Mine was £69 + vat from Skoda in 2010
Offline Russ_leeds
« Reply #14 on: September 04, 2011, 07:07:39 pm »
cheers. what would cause such a big difference in boost actual to requested?
