Author Topic: Nearly finished, thoughts on final tweeks !  (Read 4292 times)
Offline lamas
Re: Nearly finished, thoughts on final tweeks !
« Reply #15 on: September 06, 2011, 08:38:47 am »
This thread might help http://www.mk5golfgti.co.uk/forum/index.php/topic,28835.0.html
I currently run 3-5mm higher but this was the base settings :
Ride height 338 mm
Camber L -2 deg 10 mins, R -2 Deg 0 mins
Toe L - 6mins, R - 6mins (toe out)
Caster L 8 deg 13 mins, R 8 deg 14 mins
SAI L 16 deg 36 mins, R 16 deg 21 mins
Bilstein PSS10 setting 3/10
Neuspeed 25mm bar full soft
WALK
Tyre pressure 35 psi after a 20 minute normal journey (32.5 cold)
Tyre Pirelli P Zero 225/18 92Y XL MO
Rear
Ride height 324mm
Camber L -1 deg 37 mins, R -1 deg 30 mins
Toe L 6 mins, R 7 mins (toe in)
Bilstein PSS10 setting 4/10
Neuspeed 25mm full hard
Tyre pressure 33.5 psi after a 20 minute normal journey (31.5 cold)
How do you calculate the Ride height? Form where to where?
I also have the PSS10 with similar settings (just 1 click harder on the rear because I haven't got ARB) and I would like to compare if height is similar.
Offline Carrera2RS
« Reply #16 on: September 06, 2011, 08:53:20 am »
Sorry, the ride heights are from the wheel centre to the archlip, straight up. You will find small differences with wheel offset (as the wheel centre might be marginally more in or out affecting the length fractionally)
I put the start of the tape on the wheel centre, go straight up and where the tape hits the bottom of the arch take a measurement
Stock ride heights are 360mm ish. My measurements are currently 342mm F 326mm R
Offline lamas
« Reply #17 on: September 06, 2011, 10:27:59 am »
I have always read that back should be higher than front (just 10mm)... What do you think about?
Offline Carrera2RS
« Reply #18 on: September 06, 2011, 11:43:33 am »
I have tried a lot of options and did not find the Golf perfomed well nose down. It simply understeered more........
Plus the front geometry does not perform well too low. I did try the back at 330 and 335 and 350, it lost the balance. I would like to run the rear a little higher but as I move from the current heights the balance and grip is reduced for my set up and my handling preferences
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #19 on: September 06, 2011, 03:08:21 pm »
Carrera thanks sent  :drinking:
