Author Topic: Dip stick smells of petrol!!  (Read 12601 times)
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: Dip stick smells of petrol!!
« Reply #30 on: September 06, 2011, 07:00:41 pm »
So the general concencus is the APR is good for 50k?  Only 10k to go!  :scared:
 :popcornsoda:
If you see my response a few posts up i said i was referring to the Autotech not the APR.
The Autotech/KMD failings can range from 5k miles to 50k miles or more. There is no set pattern to the failures.
However i have yet to read anything of an APR failure (Although i'm sure a Google warrior will find a thread somewhere and post it up  :evilgrin:)
« Reply #31 on: September 06, 2011, 07:02:24 pm »
 :popcornsoda:
Thanks  :happy2:
Offline baldwined30
« Reply #32 on: September 06, 2011, 07:03:25 pm »
HELP ME WITH MY NUT :jumping: :jumping: :rolleye: :rolleye:
Ed30
« Reply #33 on: September 06, 2011, 07:03:52 pm »
Not straight forward but here you go.
http://www.golfmkv.com/forums/showthread.php?t=155515
Offline QD MBE
  • -Receive: 102
« Reply #34 on: September 06, 2011, 07:09:20 pm »
Decent Molegrips are the way forward.  Grip on the flats (what's left of them) as tight as you can go.  Did you release the fuel pressure?
Don't open the drivers door whilst that valve is out.
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #35 on: September 06, 2011, 07:11:11 pm »
Speak of the devil and he shall appear  :evilgrin: :grin:
Offline baldwined30
« Reply #36 on: September 06, 2011, 07:13:11 pm »
my ones are pretty crap and hungry for brass, yea released the pressure! ive been trying for ages! i dont know if i can face any more!!!! Whats more annoying is i fitted my S3 intercooler last night with no problems!!!! WTF!!!!!
Ed30
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #37 on: September 06, 2011, 07:15:22 pm »
Have you got a 10 or 11mm Deep Socket?
Thats what i used not mole grips. They are on fairly tight, but not normally that tight, and i had to replace mine as i had tightened it too much when i fitted the Autotech internals.
Offline baldwined30
« Reply #38 on: September 06, 2011, 07:17:32 pm »
carl, where abouts are you buddy!? Ill prob have another go at some point but right now im out of gas! Would it be better when its cool? I have got a socket that will go on it yes! I dont remember putting it in that tight!!
Ed30
Offline QD MBE
  • -Receive: 102
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #40 on: September 06, 2011, 07:22:03 pm »
I'm near Salisbury mate.
I would remove your intake so you can get decent access and then gently but firmly tap on the Socket. Then use that to get it off. You have done too much damage now to get it off with mole grips and unless you can get the Nut extractor that QD has linked then a socket will be your best bet.
Offline baldwined30
« Reply #41 on: September 06, 2011, 07:25:21 pm »
Well theres yea took the intake off! Think I tightened it first thats whats messed it up! Think I will order one of these sets now! That will save me shelling out for a new pump!! Wouldnt mind but im 29 not 19!!!
 Cheers Fellas!!!!
Ed30
Saint Steve
« Reply #42 on: September 06, 2011, 08:11:01 pm »
What about a stud extractor.. I used to use it for removing cylinder head studs effectively ..
Snap On tools make one
h4rdy
« Reply #43 on: September 06, 2011, 08:20:15 pm »
Eezee outs would do it.
Offline baldwined30
« Reply #44 on: September 06, 2011, 08:40:00 pm »
Thanks guys!! Any pics so I order the right thing!! Thanks chaps!
Ed30
