Author Topic: Dip stick smells of petrol!!  (Read 12801 times)
Saint Steve
Offline baldwined30
Re: Dip stick smells of petrol!!
« Reply #46 on: September 06, 2011, 10:17:07 pm »
How does that work?? I know I'm being thick!!
Ed30
Saint Steve
« Reply #47 on: September 06, 2011, 10:20:44 pm »
If you put a Ratchet  in the top and turn it, the more you turn, the tighter it bits without looking like a hamsters chewed the valve :signLOL:
It's a great tool. . It says it opens to half inch which should be big enough to go over the valve and enable you to turn it to undo it :happy2:
Offline baldwined30
« Reply #48 on: September 06, 2011, 10:30:14 pm »
I know, I'm ashamed of the bodge!! I can't wait to get it out! Think ill go srew fix and get that tool! It looks soooo awful!!!! Do you think a garage will be able to get tit out?
Ed30
Offline QD MBE
  • -Receive: 102
« Reply #49 on: September 06, 2011, 10:34:17 pm »
TBH I don't think that Snap on Stud extractor tool will work, could be proven wrong, and happy to be so, but the end portion of the valve is hollow, and that tool works by gripping (hence squeezing) a stud to remove.
Unless you can get it flush with the pump body (ie gripping on the full length - which will be difficult)
You need to grip on the hexagonal (what is left of it) part.  Hence the need for a Nut/Bolt extractor, and my advice to grip the most solid area (the Hex area)
As i say happy to be proven wrong.   :happy2:  Just my experience and thoughts.
Hope you get it out soon.  I have a set of the Irwin Bolt/nut removers only after experiencing them at work, and have used them on various parts of a helicopter and on brake caliper bolts that had rounded on a MK3 Golf, and they do the job very well.
« Last Edit: September 06, 2011, 10:36:29 pm by QD »
Saint Steve
« Reply #50 on: September 06, 2011, 10:34:28 pm »
Yes, it's only brass mate, so a stud extractor will get that out no problem.
ask at you local garage, most good engineers should have one, and will know what you need mate :happy2:
Snap on's stud extractor tightens on the widest part... That being the old hex head of the valve, and not the body.
my only concern is whether it will get enough purchase on it, and they normally undo long Cylinder head studs unto 19mm on some sized extractors with ease.
All else fails, get a pair of Molsons :signLOL:
« Last Edit: September 06, 2011, 10:46:29 pm by Saint Steve »
Offline PDT
  • -Receive: 142
« Reply #51 on: September 06, 2011, 10:55:55 pm »
Remove the whole pump assembly and use a vice, a proper set of mole grips and clamp them tight.
Offline baldwined30
« Reply #52 on: September 07, 2011, 07:04:35 am »
Problem is, I can't get the pump off as that valve is in the way of one of the T30 bolts!
Ed30
Offline PDT
  • -Receive: 142
« Reply #53 on: September 07, 2011, 07:30:36 am »
Get yourself to a local tool shop, Halfords, machine mart etc... And get a small pair if stilson grips or mole grips and should come out easily.
Offline baldwined30
« Reply #54 on: September 07, 2011, 08:01:04 am »
To be honest the mole grips I used wre sh*te and old!! I'm on my way to work and can't stop thinking about it! Haha how sad!
Ed30
Offline micky 32
« Reply #55 on: September 07, 2011, 10:29:31 am »
Just to add, i have 65k on my Autotech internals.
2008 Octavia vRS K04'd , Forge twintercooler, Evoms, Autotech uprated pump, full Milltek exhaust 324bhp on JKM's rollers ;-)
Offline baldwined30
« Reply #56 on: September 07, 2011, 10:36:32 am »
Just bought my iwrins bolt removal kit!! Wish me luck!!!
Ed30
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #57 on: September 07, 2011, 10:39:31 am »
...........keep us posted  :happy2: & good luck. :wink:
Offline baldwined30
« Reply #58 on: September 07, 2011, 10:43:11 am »
Well if it doesn't work, look out for it in the for sale section hahah! Cheers gents!!
Ed30
« Reply #59 on: September 07, 2011, 12:44:30 pm »
Would that be the car or the pump?   :laugh:
Good luck   :happy2:
