Author Topic: IPOD / I Phone connect to rns 510  (Read 3547 times)
Offline gobbleplease
  • -Given: 64
  • -Receive: 48
« on: September 06, 2011, 09:44:48 pm »
Ive tryed everthing trying to connect this to my ipod nano (old generation) and i phone and it doesnt work with the RNS 510, does this unit as shown in the picture above even function with the RNS 510 or do i need something else ?
Ive also heard that if i connect my 3GS to the rns it wont work in bluetooth mode is this true ?
« Last Edit: September 06, 2011, 10:30:50 pm by gobbleplease »
MK7 GTI - ARRIVING DECEMBER
Offline alexperkins
  • -Receive: 99
Re: IPOD / I Phone connect to rns 510
« Reply #1 on: September 09, 2011, 05:22:11 pm »
It will function with the RNS510, but it won't display track names or charge newer iphones/ipods that only can charge via USB
Offline damoegan
« Reply #2 on: September 09, 2011, 05:39:55 pm »
Mine plays my gen2 Nano just fine.
Also plays my new iPhone 4 just fine  :smiley:
Offline alexperkins
  • -Receive: 99
« Reply #3 on: September 09, 2011, 05:43:33 pm »
But it doesn't charge it  :P
Offline damoegan
« Reply #4 on: September 09, 2011, 05:47:18 pm »
True  :sad1:
And you cant close the armrest led with it in there   :fighting:
  • -Given: 64
  • -Receive: 48
« Reply #5 on: September 09, 2011, 09:46:24 pm »
Cheers guys the problem is how do i access the ipod via the rns ?
When i plug the ipod in i cant use the ipod as when its in the dock the buttons are inaccessable ?
Problem 2 is when i go in to media in the rns it basically tells me that nothing is there
Any suggestions do i need enable something on the rns ?
Offline damoegan
« Reply #6 on: September 09, 2011, 10:23:58 pm »
Media > MDI  :happy2:
  • -Given: 64
  • -Receive: 48
« Reply #7 on: September 09, 2011, 10:45:51 pm »
Awright cheers, so whats the script with the ipod in the arm rest what do you go in to play that ?
Offline alexperkins
  • -Receive: 99
« Reply #8 on: September 09, 2011, 11:49:33 pm »
Thats not an MDI iPod Dock at all...
Its Media > CD Changer
You'll have 6 available discs. 1-5 are your first 5 playlists, and 6 is all tracks
  • -Given: 64
  • -Receive: 48
« Reply #9 on: September 10, 2011, 09:59:48 am »
Cheers alex i thought so ! Thats where the cd changer is and i think im right in saying that the ipod dock is basically the cd player ! Ill try again today if i cant get it working ill take the rns back out and make sure everything is conected correctly at the back !
Offline alexperkins
  • -Receive: 99
« Reply #10 on: September 10, 2011, 12:29:36 pm »
Correct
When its out, make sure the earth pin for the iPod dock wire is in the right place also as it has to be moved to sound right on the RNS systems
  • -Given: 64
  • -Receive: 48
« Reply #11 on: September 10, 2011, 03:38:35 pm »
I got it working although the rns needs to be switched off, ipod inserted and then switched back on for it to recognise the ipod is there. If you simply dock the i pod when the rns is on is does not see it??
The sound is really bad too, you were saying alex that this could to be to do with the earth pin being in the wrong position when you upgrade from rcd to rns ?
Is there a diagram available for repositioning the earth or a plug and play connector
