Author Topic: EML on GTTdi  (Read 1996 times)
Offline will130787
EML on GTTdi
« on: September 07, 2011, 11:45:04 am »
Hi guys, I have an Engine Management Light on at the moment. The display says 'Emissions Workshop!'. The first thing I thought was DPF however i'm not sure it has one being 2004, next EGR? Is the only way to get a Diag reading to go to VW?
Offline vRS_Pagey
  • -Receive: 59
Re: EML on GTTdi
« Reply #1 on: September 07, 2011, 11:56:00 am »
No DPF on a 2004, it could be the EGR valve or a lamda sensor?  Your dealer could read the fault code, but I'm sure a lindly member with VCDS will oblige.  If the code is P0401 then it is the EGR, an option would be to fit a delete pipe, they are only £70.
Offline will130787
Re: EML on GTTdi
« Reply #2 on: September 07, 2011, 12:29:31 pm »
Thats what I was thinking, no DPF. Is there any benefit of the delete pipe? They appear to be £75 for a new valve.....
Anyone roughly around Reading that could read this for me?
Offline will130787
Re: EML on GTTdi
« Reply #3 on: September 07, 2011, 12:35:19 pm »
I have just read the thread 3 down from mine regarding the benefits, also looks like a no brainer!
Offline gizmo68
  • We're here for a good time, not a long time
Re: EML on GTTdi
« Reply #4 on: September 07, 2011, 12:38:26 pm »
Take a look on the VCDS Owners Register:
http://www.mk5golfgti.co.uk/forum/index.php/topic,120.0.html
VCDS HEX-NET & VCP owner (covers all VAG cars)
(PM me if you require VCDS or VCP coding or scanning in Kent)
Offline vRS_Pagey
  • -Receive: 59
Re: EML on GTTdi
« Reply #5 on: September 07, 2011, 01:14:47 pm »
 :signLOL: Thats my post!  :happy2:
Offline Scousus maximus
Re: EML on GTTdi
« Reply #6 on: September 07, 2011, 01:25:08 pm »
Isn't it nice when two bits of info come together at just the right time?
Regards
John
Offline will130787
Re: EML on GTTdi
« Reply #7 on: September 07, 2011, 01:57:41 pm »
Thats mighty handy, thank you. I have sent a PM but it doesn't seem to now be in my outbox.....
Offline vRS_Pagey
  • -Receive: 59
Re: EML on GTTdi
« Reply #8 on: September 07, 2011, 02:36:44 pm »
One of the most infuriating things about this forum.......when you send a PM you have to physically check the box so the sent message appears in your outbox!!  :mad:
Offline will130787
Re: EML on GTTdi
« Reply #9 on: September 07, 2011, 05:03:56 pm »
He replied which showed I have actually sent it. The ticking box is a bit arse about face!
Offline vRS_Pagey
  • -Receive: 59
Re: EML on GTTdi
« Reply #10 on: September 07, 2011, 05:29:45 pm »
Don't see any need for it either way!  :confused:
