Author Topic: Exhaust tips - carbon up very quickly, is this a problem?  (Read 3769 times)
Offline berg
  • -Given: 49
  • -Receive: 38
« on: September 08, 2011, 08:35:15 pm »
Hi chaps, after a session with the wire wool and autosol i had the tips quite respectable on sunday.
I notice today that they are pretty black again - is this normal or is it a sign the the AFR needs altering?
Many thanks.
Offline DJM
  • -Given: 28
Re: Exhaust tips - carbon up very quickly, is this a problem?
« Reply #1 on: September 08, 2011, 08:37:47 pm »
What sort of mileage you doing? Probably normal. Mine are really bad :( spent an hour with wire wool n autosol and still black. Dont think they had ever been cleaned before prior to me buying it
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #2 on: September 08, 2011, 08:38:46 pm »
quite low mileage, only 3 miles to work so engine only just warmed up before i end up switching off
Offline chris s
« Reply #3 on: September 08, 2011, 08:42:34 pm »
Berg I noticed exactly the same thing  on mine, and I do the same mileage as you each day.... and wondered the same thing.  Got a TBE fitted on Monday so will see if the same build up happens
Candy White Edition 30 DSG
Revo Stage 2+
ITG, BCS TBE, Autotech HPFP
WALK
R32 Brake upgrade
S3 IC upgrade
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #4 on: September 08, 2011, 08:49:59 pm »
yeah let me know, i have pipewerx downpipe but still have oem exhaust at mo
Offline chris s
« Reply #5 on: September 08, 2011, 08:51:25 pm »
pretty sure all is well tho, but I have changed the plugs and coil packs in the last month so just hope it's nothing to do with that
Revo Stage 2+
WALK
R32 Brake upgrade
S3 IC upgrade
« Reply #6 on: September 08, 2011, 10:06:34 pm »
Sounds pretty normal on a gti...
Offline Leonard
« Reply #7 on: September 09, 2011, 07:24:26 am »
 Mine do it. Coke :jumping:d back up after a week of commuting :(
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #8 on: September 09, 2011, 07:34:25 am »
Best thing to do after a really good clean is every couple of days just give the pipes a wipe over with a soft cloth & they will stay nice & shiney. :happy2:
Offline OEM+ DUB
« Reply #9 on: September 09, 2011, 08:28:13 am »
Perfectly normal.  My commute is 4 miles each way and mine start to look dirty within a week.
OEM+ 2005 GTI DSG (high factory standard spec and upgraded with S3 alloy hubs, S3 alloy wishbones, Bilstein B8s and VWR springs by my own hands) owned since 2008 and still loving it!
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=pp5d5eukmv0b59q9t93snirl5s&/topic,19740.0.html
« Reply #10 on: September 09, 2011, 09:16:02 am »
Mine go black quickly. I have thought about getting them black ceramic coated.
Offline Kalpsn2000
  • -Receive: 56
« Reply #11 on: September 09, 2011, 11:26:36 am »
Do any of you put a sealent (I assume it has to be hi-temp) on the tail pipes after cleaning them?
Mine need cleaning and got a next week off so was planning on doing them.
Offline DJM
  • -Given: 28
« Reply #12 on: September 09, 2011, 01:08:07 pm »
Whats it sound like with that? Do you have decat? I was looking at the pipeworx downpipe and decat with oem exhaust.
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #13 on: September 09, 2011, 01:40:27 pm »
...........after giving mine a good clean with metal polish i give them a final spray with ''stainles steel'' cooker top cleaner.Works a treat.
Offline david25
  • -Given: 19
« Reply #14 on: September 09, 2011, 03:41:35 pm »
Yes, I used collinite 476s wax after cleaning with normal kitchen cleaner solution.
The wax makes it much eaiser to remove any black next time.
