Author Topic: Water meth  (Read 3776 times)
Offline JackG
  • -Given: 33
  • -Receive: 31
    • Distinct Detailing
Water meth
« on: September 10, 2011, 09:28:10 pm »
Guys, I've had a search of wich has helped me out BUT I want a honest answer of someone that's using it already as I believe it's getting more popular!
Is it worth it??!! The cost of a kit is around £300 for devils own I am planing on going stage 2+ (2008 ed30)
I won't bother if I get a increase of around 8bhp  :signLOL:
Any help would be greaaaatttt!
Jack
www.distinctdetailing.co.uk
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: Water meth
« Reply #1 on: September 11, 2011, 09:56:26 pm »
&feature=related
i remember as well reading somewhere else that gains are comparable to fitting a decent CAI. i've tried searching for it but i can't find it. if i come across it i'll post.
S.
PLANS: Stage 2+
Offline berg
  • -Given: 49
  • -Receive: 38
Re: Water meth
« Reply #2 on: April 03, 2012, 03:15:03 pm »
been looking at this, is there anyone usig it who can comment on the OP's queries?
Jack, did you find anything else out about it?
Thanks.
Offline dan930
  • -Receive: 56
Re: Water meth
« Reply #3 on: April 03, 2012, 06:03:34 pm »
I remember At r-tech theres a black mk5 Gti fitted with water-meth & it's running around 370-380bhp...
Think he's a member on here
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
Re: Water meth
« Reply #4 on: April 03, 2012, 06:09:58 pm »
http://www.mk5golfgti.co.uk/forum/index.php/topic,43854.0.html
Offline luckyGti
  • -Receive: 27
Re: Water meth
« Reply #5 on: April 03, 2012, 06:52:36 pm »
I run a snow performance stage 3 kit with 7 gallon tank in the boot, definitely a noticeable gain in power and well worth it imo.
James will be able to give a better explanation of the benefits/gains as mine isn't set-up to it's full potential at the moment.
Stage 3 Snow video
Aem
&feature=related
« Last Edit: April 03, 2012, 07:28:15 pm by luckyGti »
Offline james
Re: Water meth
« Reply #6 on: April 03, 2012, 11:02:11 pm »
i have been playing with mine running 50/50 60/40 70/30 and 100% meth
100% meth is epic! lol but i now run 70/30.
i get around 60/70BHP from it due to me running loads of advance timing.  :drinking:
The car needs to be mapped to it  :happy2:
Offline skiddusmarkus
Re: Water meth
« Reply #7 on: April 04, 2012, 08:04:59 am »
The main benefits are that it cools inlet charge and cylinder temps, allowing you to run more boost/timing.
Water is better at cooling the inlet charge and methanol is superior in the cylinders, plus it also boosts octane.This is why people run a mix, although some run a small % of methanol to stop water freezing in cold conditions.
I have it fitted but atm its just spraying water.The reason being is methanol is highly toxic and I don't particularly want to store something so flammable in large quantities.
When my car was mapped, it was done with the WO off(not what I asked for), so when its on, it actually loses around 8bhp as you have to lean off the mixture when spraying and this hasn't been done as yet.
Offline james
Re: Water meth
« Reply #8 on: April 04, 2012, 09:36:39 am »
i have tried to see if it is flammable 50/50 and does not burn
but burns at 70/30.
Re: Water meth
« Reply #9 on: April 04, 2012, 03:54:46 pm »
Just remember that aluminium and methanol are not best buddies...
Offline james
Re: Water meth
« Reply #10 on: April 04, 2012, 06:54:43 pm »
yea i know, doing a test in the garage,   100% with a lump of ally to see how long it takes.
Offline berg
  • -Given: 49
  • -Receive: 38
Re: Water meth
« Reply #11 on: April 04, 2012, 07:35:21 pm »
James - are there serious negative points to running water meth?
Re: Water meth
« Reply #12 on: April 04, 2012, 07:36:48 pm »
Corrosion of your valve guides with high meth mix  :scared:
Offline damoegan
Re: Water meth
« Reply #13 on: April 04, 2012, 08:06:48 pm »
Lots of cases of throttle body failur due to meth ingress on the 1.8T...
Offline berg
  • -Given: 49
  • -Receive: 38
Re: Water meth
« Reply #14 on: April 04, 2012, 09:30:47 pm »
mmmm, so am thinking if TFSI Mike does not have it there must be a reason as Mike, you seem to have every other mod under the sun!
