Author Topic: Electrical problems... HELP please!  (Read 4409 times)
Offline will130787
« on: September 13, 2011, 02:12:18 pm »
Hi guys, 2nd time of trying due to my pc switching itself off!
Right long story, bear with me please.
Saturday morning I decided to switch my stereo over for a double din unit I bought through here. I went to Halfrauds and bought the correct loom adaptor etc for a small fortune.
I proceeded to swap them over and quickly deduced that it was not working on ignition power but staying on constantly. So i did the old trick of swapping the constant and ignition power leads which led to a fuse blowing in the engine bay board, so I swapped it over with another one for the purpose of a trial and blew it again, repeated the same and by this time starting getting in a tizz. Thought I will leave it and got in the car to go and get some more fuses, wouldnt start! Turned over etc but didnt fire up. Starting funking about again and managed to get it started, left home, 1/2 mile down the road it just stopped running. Checked all the fuses again and none had blown..... ended up getting towed home.
Yesterday Dom came round (a fellow Reading member with VAGcom) to have a look at it for me, he plugged in and did the diag check, this is the report:
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 1010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 1010
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0103
   Coding: 0023170
   Shop #: WSC 00036 210 07788
   VCID: 3A70F51A0CCF
4 Faults Found:
01314 - Engine Control Module
            013 - Check DTC Memory - Intermittent
00474 - Control Module for Immobilizer
            004 - No Signal/Communication - Intermittent
01299 - Diagnostic Interface for Data Bus (J533)
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 L
   Component: ClimatronicPQ35 061 0201
   Shop #: WSC 00000 000 00000
   VCID: 3064D732DAB3
6 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
00797 - Sunlight Photo Sensor (G107)
            010 - Open or Short to Plus - Intermittent
00709 - Sunlight Photosensor 2 (G134)
01316 - ABS Control Module
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 L    HW: 1K0 937 049 L*
   Component: Bordnetz-SG 1.0 H30 0701
   Revision: 00030000    Serial number: 00000000432912
   Coding: E5898F0600041800001400001400000000
   VCID: 3874EF1232C3
   Component: Fehler Lin-Slave 01
   Component: Fehler Lin-Slave 02
9 Faults Found:
02071 - Local Databus
01321 - Control Module for Airbags (J234)
01800 - Light Switch (E1)
            008 - Implausible Signal - Intermittent
00059 - Terminal 30 for Interior Lighting
            012 - Electrical Fault in Circuit - Intermittent
00834 - Signal for Activation of Heated Rear Window
            009 - Open or Short to Ground - Intermittent
00926 - Terminal 30
            011 - Open Circuit - Intermittent
00906 - Horn (H1)
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 A    HW: 1K0 909 605 A
   Component: 0M AIRBAG VW8   022 0500
   Revision: 04022000    Serial number: 0033FD07L0M+
   Coding: 0012365
   Shop #: WSC 01279 785 00200
   VCID: 2A50C55AFC6F
1 Fault Found:
            004 - No Signal/Communication - Intermittent - MIL ON
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
   Component: Lenksäulenmodul 012 0030
   Coding: 0000012
   VCID: 3064D732DAB3
1 Fault Found:
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K0 920 960 L
   Component: KOMBIINSTRUMENT VDD 3354
   Coding: 0001401
   Shop #: WSC 00036 067 57207
   VCID: 3260DD3AD4BF
2 Faults Found:
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 C    HW: 1K0 907 951
   Component: Gateway         H08 0080
   Revision: 08          Serial number: 21001041146F4A
   Coding: 3D3F0B40070003
   VCID: 27563C6EEF7D
4 Faults Found:
01305 - Databus for Infotainment
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 1
                    Fault Frequency: 90
                    Reset counter: 55
                    Mileage: 170001 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:28:42
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 90
                    Reset counter: 55
                    Mileage: 170001 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:28:45
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 16
                    Reset counter: 15
                    Mileage: 170019 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:04:36
00466 - Control Module for Steering Column Electronics (J527)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 55
                    Mileage: 170020 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:29:44
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO                3354
   VCID: 3260DD3AD4BF
No fault code found.
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0116
   Coding: 0000052
   VCID: 3064D732DAB3
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 E
   Component: EPS_ZFLS Kl.3       1202
   VCID: 2E58C94AC087
2 Faults Found:
            004 - No Signal/Communication - MIL ON
             Freeze Frame:
                    Mileage: 0 km
                    Temperature: 24.0°C
                    Voltage: 12.20 V
                    Voltage: 12.00 V
00778 - Steering Angle Sensor (G85)
            000 -  -  - MIL ON
             Freeze Frame:
                    Mileage: 0 km
                    Count: 1
                    Steering Angle: 0.00°
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 BL
   Component: 01 KSG              0301
   Coding: 81E802087F2D8505485FC61000
   Shop #: WSC 00036 210 55224
   VCID: 7BFE301E4375
   Part No: 1K0 951 605 A
   Component: LIN BACKUP HORN H01 1201
   Part No: 1K0 907 719
   Component: Neigungssensor  003 0003
   Part No: 1K0 951 177
   Component: Innenraumueberw.004 0101
2 Faults Found:
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Coding: 0000052
   VCID: 3162D236D1B9
1 Fault Found:
00933 - Electric Window Motor; Passenger Side (V148)
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No: 1K0 035 186 G
   Component: Radio BNO           0013
   Coding: 0040400
   VCID: 2A50C55AFC6F
2 Faults Found:
01044 - Control Module Incorrectly Coded
            000 -  -
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 C
   Component: Tuersteuergeraet 06 0202
   Coding: 0000016
   VCID: 3064D732DAB3
1 Fault Found:
00934 - Electric Window Motor; Rear Left (V26)
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 C
   Coding: 0000016
   VCID: 3162D236D1B9
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 C    HW: 1K0 963 235 C
   Component: PTC-Element         0404
   Revision: 00600000    Serial number:
   VCID: 2B5EC05EF395
The main problem is that the VAGcom will not communicate with the engine control module. My theory is that I have replaced a fuse with a higher ampage one and blown the relay however I have no idea which one it is likely to be.
Has anyone ever seen this before? If so what was the final cause?
Thanks  :happy2:
Offline Scousus maximus
Re: Electrical problems... HELP please!
« Reply #1 on: September 13, 2011, 09:04:51 pm »
Not heard of this before. It might be worth dis-connecting the battery and the new kit and then re-connect the battery and see what that gives you.
Did you get a CEL when the car stopped?
Not much I can think of really, hope you get it sorted.
Regards,
John
Offline will130787
« Reply #2 on: September 13, 2011, 10:16:59 pm »
I have done the disconnect, reconnect thing. Made no odds! Also I didn't get a CEL when it stopped, just stopped.....
