Author Topic: will audi wheels fit a golf?  (Read 8780 times)
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: will audi wheels fit a golf?
« Reply #1 on: September 13, 2011, 08:01:54 pm »
if yours is a mk5/6 then yes. if it's a mk4 then no because the PCD is different.
just bear in mind that these wheels are a fair bit wider than your current ones. your current ones (if OEM GTI) will be 18x7.5 rather than 18x9 (the number at the end is the width of the wheel in inches)
also the rolling radius will be different for those tyres so you'll need some coding to get your speedo accurate.
i wouldn't know if the standard issue 225/40 will fit on those because of how wide they are.
« Last Edit: September 13, 2011, 08:03:28 pm by sub39h »
PLANS: Stage 2+
Offline daz5182
« Reply #2 on: September 13, 2011, 08:08:37 pm »
yeah it is a mk5 but didn't notice the width, i think 9 is a bit much....
Thanks for the heads up mate.
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #3 on: September 13, 2011, 08:12:25 pm »
no problemo
what sort of wheel you looking for? i've seen a gorgeous set of BBS RSIIs on the wheel sanctuary, freshly refurbed and going for a VERY reasonable price. the only reason i've not bought them myself is because i don't think they'd suit my A3. they'd look MEAN on a Mk5 tho.
http://www.wheel-whores.com/classifieds/showproduct.php?product=6214&title=18-26quot-3b-bbs-rsii-split-rims&cat=4
PLANS: Stage 2+
Offline MitchGTI
« Reply #4 on: September 13, 2011, 08:13:52 pm »
9j will be fine if the ET is high i think they might be ET52
Offline patrickcullen87
« Reply #5 on: September 13, 2011, 08:39:10 pm »
i bought BBS CH for my Audi A3 but had to buy a spacing ring the centre of it to fit the mk5 gti.....was a bit of a hassle as BBS has a funny offset size and i couldnt find anyone that could get a hold of them, eventually had to go through BBS and buy a full set off them including bolts etc.
but back to topic yeh they should fit  :grin:
Admin Notice Sig Removed - Signature images should be no bigger than 450 pixels wide x 150 pixels high
Offline daz5182
« Reply #6 on: September 15, 2011, 09:15:39 am »
cheers for your replies, that makes more sense then, i think 9" is a bit wide for what i want and et 43 may cause rubbing at the front i have found out....
This wheel lark is a bit complicated!
