Author Topic: disappointing performance continued....UPDATED after a day at MRC Tuning  (Read 20226 times)
Offline WhiteGTI
  • F-A-S-T
Re: disappointing performance continued....
« Reply #45 on: April 02, 2009, 10:59:55 am »
As above, a sensor is more than likely playing up or you have a boost leak. If it's over-fuelling across the rev range then it could well be a MAF or lambda sensor.
it is only running super rich past 3500rpm to the limit
Very interesting  - sounds like the exact opposite to my issue which is fuel too lean past 4k rpm
So does this mean that where MRC tuning have altered the map to counterract the richness past 3500, that it now runs too lean up to 3500?? Just curious that's all!
Also, with regard to what Illyun said above, could it be a problem with the actual injectors then?
2006 E46 BMW M3 - 343hp
Offline duncan
in terms of the richness
we were only getting problems with the car being too rich when the throttle was wide open and we were over 4500rpm. which was much better than the previous day
this was at the start of the day before the remap went on.
are the injectors faulty? well the ECU is requesting the extra richness so not sure if that rules them out or not.
the car is running fine in the lower rev range - the change made to the richness in the code is that the fuel ration is set on a limit so the ECU does not let the car dip below 11.5afr and bearing in mind this was only happening at pretty high revs.
not sure if ive explained that correctly....
going back to the Richness problem - what else could you have done to see why it was running too rich at high revs? was tricky becuase im guessing it is very difficult to know why the ECU wants more fuel than it should do when you have ruled out the obvious possilbe causes.
one thought was that the latest version of software on the ECU was set to run too rich... not sure if thats a possibility or not
Candy white GTI, MRC tuning Remap - the rest will remain standard...
Offline ub7rm
  • -Given: 35
  • -Receive: 43
I havent' fully read your 'other' thread so apologies but I gather there is a question mark over where your car is from?
I'm just thinking aloud here but is it possible that for other countries a different 'stock' map is applied to the ECU to counteract for example higher ambient temperatures (though if anything I would have thought this would result in a leaner mix), the quality of the fuel available in that part of the world etc etc.
Presumably when an update is applied, the correct update is applied depending on the serial number of the ECU.  So even if you took it into a UK VW dealer, an update for the UAE map would be applied?
I'm not sure how a map works, does it completely overwrite the stock map or does it just 'add' values to it.  I.e for a given set of conditions increase fuel by 5%......
I can see the different stock map for different regions being a possibility, but my theory might be out of the window considering you have the same problem with the performance map....
Sepang Blue S4 BE Avant
Offline duncan
i think the issue of the car being an import and having a strange country code i dont think is the problem. the car was delivered to the uk without any miles on the clock in september 2006 the date of its first registration.  however the car was manufactured late 2005, again i dont think this is the issue.
the stock map seemed to want to run too rich at high revs, i dont think this as an isolated problem is that big a deal.  what is strange is that the ECU is requesting to much fuel, after doing alot of diagnostics there was nothing to prove why the ECU was demanding too much fuel at very high revs. replacing the DV / PCV seems to have sorted the power issues and helped with the richness but not entirely. with this remap in its generic form they dont mess too much with the fuel ratio side of the map but in my case they did put a liimit on the fuel mixture which seems to have cured the problem since the car is throwing no error codes under load or after being driven. all the data coming from the car with the latest custom map seems to be looking spot on.
the tuner spent a very long time with the car before he put the map on and then spent a while looking through the data trying to establish if it was a faulty part on the car that was causing the richness issue, since nothing could be found after extensive data logging, all he did was imposed a limit on the cars ECU forcing it not to over fuel, since this has happened the power has been hugely increased, the fuel economy seems to have slightly improved but nothing majorly noticeabe and after driving 100 miles with the new map, the car was data logged and checked for any faults and the only thing that came up was an immobiliser fault which seems to be quite random and is not throwing any numbers up on the dash, this could be due when the ECU was being flashed the flash failed and had to be reapplyed which threw up electrial fault codes but nothing functional going wrong wtih the car.
all in all i would love to say the problem is completley solved.. i dont know for sure and i guess only time will tell; but as mentioned before if the data is looking correct under the new map including the fueling which is now running spot on again along with fuel pressure, boost pressure, MAF, what else could it be?
if there is a problem it cant be to big i guess my point is - if when the car is on load and not throwing up incorrect numbers or fault codes, it is near impossible to see why the over fueling occured in the first place and why it continued to occur during the mapping process
for me i guess it points to the ECU, and possibly when the WALD remap was applied the changed some fundamental Fueling instructions that would usually stay as normal when applying other maps, this would lead to the ECU constantly requesting too much fuel for the simple fact that the data on the ECU was set to do (that could have been the worst explanation ever stated on this forum, but hopefully you know what i mean)
again I agree that getting a remap wtih an undiagnosed problem leading to running rich isnt ideal, but when nothing points to a part failure leading to it then what else can you do apart from tell the ECU to stop making incorrect requests
Thoughts on this?
Offline ub7rm
  • -Given: 35
  • -Receive: 43
"the stock map seemed to want to run too rich at high revs, i dont think this as an isolated problem is that big a deal.  what is strange is that the ECU is requesting to much fuel, after doing alot of diagnostics there was nothing to prove why the ECU was demanding too much fuel at very high revs. replacing the DV / PCV seems to have sorted the power issues and helped with the richness but not entirely. with this remap in its generic form they dont mess too much with the fuel ratio side of the map but in my case they did put a liimit on the fuel mixture"
Thats what makes me think that your ECU is behaving exactly as it should.  All the sensors and diagnostics are coming up clean.  When I say its behaving exactly as it should, its doing what it should be doing say in a country where they sell a lower grade of petrol or where some other constant 'variable' is present.  Trouble is no one has told your ECU that its no longer having to deal with that shoddy petrol or whatever and that it doesn't need to throw so much petrol in.
I know your car hasnt' physically been to a different country, but it would have left the factory with the equipment / settings for that country.
As a completely made up example, perhaps in a hot dusty country the fueling paramaters are designed to take into account that the fuel filter may be partially blocked at all times, or that due to expansion of the fuel (due to heat) that for a given number of pump cycles the volume of fuel actually delivered is less than at our ambient temperature.  Extreme but this is what I mean.
I realise its an oddball suggestion but you seem to have drawn a blank at the usual suspect.
« Last Edit: April 02, 2009, 04:14:58 pm by ub7rm »
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
nice theory ub7rm , certainly worth a letter to VW UK asking  :happy2:
Red ED35 5dr DSG
BLOG | BUILD
Offline joesgti
  • Eat my sick, Eat my sick.
+1 was think that aswell! id put this on your 'list of things to check'
Offline illyun
I thought that too, but surely the map would have addressed that as a potential cause?  BTW, its not your injectors, as my ECU is requesting the correct AFR, but its not getting through the injectors.
« Last Edit: April 03, 2009, 01:13:12 pm by illyun »
Offline duncan
thats a very good point and to be honest - the over fueling has to point to the ECU setup - the tuner thought it might of had something to do wtih the latest software that is on the ECU from VW
the only thing is if it was for a country with an extremley different climate to that of the uk / EU then it would have been produced left hand drive.
my only feeling is that when it had this WALD conversion instead of just applying a Generic map they ended up altering the fuel mixture, so when the map has been flashed due to a software update, this may not have entirely flashed the ECU's settings still leaving a kind of ghost of the privious map
not sure if that is actually possible - but again could be possible?
Offline neg
  • gone old skool
Good point but as stated most well known tuners (not sure for all) replace the map on the car with their modified version so this would rule it out.  I know Revo always work on the latest released map - e.g. when mine went in for the ECU update I was actually already running it but they didnt know so I let them apply it for piece of mind as I was under warranty.
Glad its all sorted though  :happy2:
Offline duncan
from my understanding after speaking in depth wtih MRC Tuning, Generic maps like Revo / apr / GIAC etc do make big changes to the stock map but dont adjust everything, it was only when the changes were made to my custom map that the fueling sorted it self out.
I think your right about the new release of software not being the cause of the car running rich.
to be honest am kind of quoting what ive been told / understand from the conversations i had about my car.
the APR map i had on the car didnt make changes to some of the stock settings on the ECU, it was only when he put his map on, data logged then changed the custom map for my car to change its fuel ratio that the car stopped running rich at high revs.
only issue i have with the car now is that i feel the brakes arnt quite up to it after the remap as the car is that much faster!
also am getting a rubbing / grinding when im hard lock going forwards and backwards - not too worried about this as car is underwarranty so can get it fixed easily
Offline neg
  • gone old skool
I think your is a little different to the 'norm' so you needed a completely custom map with tables being altered that normally dont need to be.
Offline ub7rm
  • -Given: 35
  • -Receive: 43
The steering noise is most likely the steering rack - all to common a problem.
I'm not an programmer but I would imagine the way most remaps work is by altering stock setting by some delta, not overwriting the absolute values.  And almost certainly not overwriting the entire map - this would be a huge undertaking by any tuner, they most likely leave the vast majority of the code unchanged, and just tweak the bits that they have to.  So if your 'stock' map is off, the remap will only increase / decrease that value by some delta.  An off the shelf remap maybe doesn't play with the parameters that are 'wrong' with your stock map which was why it was only addressed by the custom remap?
Offline duncan
very well put
i think thats what i was trying to say but couldnt quite get there!
well so far no probs with the car and the remap - still getting used to the power and am being taken by suprise every time i put my foot down
does definitley make me want to upgrade my brakes and suspension
curiousity is making me want to take it to a rolling toad but i dont want to be annoyed if the figures arnt there, am more than happy with the performance so there is little point in my book...
will wait until there is a group buy thing on!
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
tbh I have no idea how much code is changed for each remap. Although consider this...
APR remap has an OE like map which is APR's interpretation of the original VW map.
Plus VW own the orginal source code and protect it , so its an interesting point as in theory you cant 'copyVW  map' and change a few params....
My limited understanding is that there can be 2 types of tuning , 1) the (relatively) easy way by modifying limited parameters as the ECU seems them or 2) taking the whole code apart and building your own.
Interesting talking point  :happy2:
Red ED35 5dr DSG
BLOG | BUILD
