Author Topic: Shark Fin / GPS < Urgent-ish  (Read 1792 times)
Offline Johnny_tro
« on: September 17, 2011, 11:39:43 pm »
When fitting the RNS today.....noticed I had two options............
Connect either....
1) The GPS receiver to the back of it?
2) Connect the RNS to the sharks fin on the roof?
Does it matter which one?
« Last Edit: September 21, 2011, 11:42:04 pm by Johnny_tro »
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Shark Fin / GPS
« Reply #1 on: September 17, 2011, 11:43:21 pm »
sorry but this is a pointless question.
if you have a factory sharkfin for gps why would you use an aftermarket one that has to be hidden under the dash :confused:
Cluster and Key coding
Location Great Yarmouth
Offline Johnny_tro
Re: Shark Fin / GPS
« Reply #2 on: September 17, 2011, 11:46:02 pm »
? To me it isn't.....
The car (got it today) has a sharks fin, I was not sure if this COULD be used as the GPS plug in for the RNS?
Offline Richn83
  • -Given: 49
  • -Receive: 85
Re: Shark Fin / GPS
« Reply #3 on: September 21, 2011, 11:02:03 am »
use the sharkfin, it will make a big difference to the signal you get and the number of satelites it can lock on.  people only use the little puck as running the cable and installing a sharkfin when you have a bee sting is complicated and raises issues with the secondary aerial as all the cars have two.
Offline MarkMarked
Re: Shark Fin / GPS
« Reply #4 on: September 21, 2011, 08:25:30 pm »
Not all sharkfins have support for the GPS
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Shark Fin / GPS
« Reply #5 on: September 21, 2011, 08:27:49 pm »
His car does as he upgraded the factory mfd2 to an RNS510
Offline Johnny_tro
Re: Shark Fin / GPS
« Reply #6 on: September 21, 2011, 11:29:49 pm »
Thank you.....! The other reason I asked is as follows.......
1) if I use connection for the the shark fin into my RNS....would I not need to keep this connection spare for future add ons....bluetooth or anything? should I keep the GPS square thing as a back up?
2) How many items can I run through the shark fin? as I have a pre-heating thing is also connected to this?
3) I have a amp thing fitted under the drivers seat http://www.mk5golfgti.co.uk/forum/index.php/topic,35089.msg426146.html#msg426146 I have read in some cases I need to by-pass this, but I have no idea if I should, if I need to....or how to? is it causing more harm than good?
« Last Edit: September 21, 2011, 11:38:23 pm by Johnny_tro »
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Shark Fin / GPS < Urgent-ish
« Reply #7 on: September 25, 2011, 07:42:14 pm »
No because the GPS uses the Blue GPS plug, a phone kit would use a red plug
depends how many connectors are fitted to the antenna
The box under the drivers seat is a diversity switch for the mfd2, I bet you have an open circuit fault with one antenna. You need to bypass it to clear the fault for good
Offline Johnny_tro
« Reply #8 on: September 27, 2011, 10:49:33 am »
I have no errors I can see. Eddie.........?
How do I by pass this unit?  :scared: is this box specific to the MFD2 only? does it not have any plus factors for the RNS?
