Author Topic: ESP Light permanently on :S  (Read 10574 times)
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: ESP Light permanently on :S
« Reply #15 on: December 14, 2013, 01:49:38 pm »
pumps sell for peanuts on ebay, I know you don't get a warranty but if it is cheap enough who cares
Golfman bought a pump for £50 a few years back and it is still going strong
Ed
Cluster and Key coding
Location Great Yarmouth
« Reply #16 on: December 14, 2013, 07:54:29 pm »
Or you can remove your abs pump and have it repaired here http://www.ecutesting.com/vw_golf_touran_abs_pump_module.html
Offline dub singh
  • Snakebite Chasers...
« Reply #17 on: December 21, 2013, 09:49:10 pm »
vw ended up doing mine for free in the end... Changed the pump, as well as doing a full service and even providing me with a courtesy car...
If you're having Audio problems i feel bad for ya son... I've got 99 problems but Bass aint one!
« Reply #18 on: December 21, 2013, 10:37:50 pm »
result   :congrats:
Offline reaper7881
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,68492
« Reply #19 on: December 21, 2013, 11:32:05 pm »
i had this problem a while back.
ended up costing me £155 for the new revised abs pump
54 MK5 Golf 1.9tdi 3dr SMD Full Interior and Speedo Conversion, GTi Highline , Flat Bottom Wheel, ED30 Rear lights
Offline marko
« Reply #20 on: December 22, 2013, 02:01:17 pm »
Mine is 07...chanced my arm with VW who promptly told me to **** off!!!
Offline masemk5
« Reply #21 on: December 28, 2013, 11:43:14 pm »
got this problem too now.  esp and abs lights on dashboard.  not had it diagnosed yet but fairly certain its this old chestnut!
Offline xjay1337
  • -Receive: 377
« Reply #22 on: December 29, 2013, 03:01:50 am »
Would 99.9% not be this fault with BOTH lights. That would indicate a faulty sensor or something.
Offline sootpig
« Reply #23 on: December 29, 2013, 06:32:53 am »
 G201 fault which is a warranty issue.VW are obliged to fix as it is an "inherent" fault
 If your dealer is unhelpful you should ask them for the vw customer services address in order to get clarification regarding the G201 ABS fault
 I contacted my dealer by email stating I was well aware of the fault
 They booked the car in and had everything done that morning
  Before leaving the car ask if the ABS will be replaced or repaired as a repair kit is available and
 not sure how reliable it is
 £155 for the revised pump sounds very cheap
cagiva
« Reply #24 on: December 29, 2013, 01:46:12 pm »
I just got the dreaded light and a scan confirmed the G201 error so I guess I will need a new pump, not taken it to VW yet though.
Is there just one pump on the cars, or is it one for each wheel?
The BBA Reman service is my first though - if I removed my pump I can get it repaired by then then sent back to me?
Is removing the pump difficult? Are there any guides? I don't have many tools and have no way of lifting my car. My thoughts are that if the tools etc. cost under £400 or maybe even more, then its a saving.
Offline xjay1337
  • -Receive: 377
« Reply #25 on: December 29, 2013, 01:47:41 pm »
It's quite easy, take the battery and battery tray out, takes about an hour.
Offline marko
« Reply #26 on: December 29, 2013, 01:51:48 pm »
Tbh mate....judging by the questions you ask..it would be best for you not to mess with your car..bring it to a local garage and they can sort it for in around 300 quid i would guess...2 hour job for someone in the know!!
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #27 on: December 29, 2013, 01:55:46 pm »
Took me 3 hours to change mine
I reckon I could do it in 2 now that I've done one
apart from the changing of the pump
Full brake bleeding
You will need to do basic setting, check the adaptions channels are correct and re-code the module with VCDS
Offline winrya
« Reply #28 on: December 29, 2013, 05:01:57 pm »
While i was selling my 05 gti the g201 fault occurred.  VW fixed free of charge without question even though it had been serviced at a specialist for the past 4 years.
They said I had to pay for a scan, if it came back as this fault, vw automatically pay the whole lot.  No charge at all in the end and they did everything the same day.  I already knew it would be this fault as it had been scanned by my specialist so was no risk.
Shocking some dealers don't help out.  I did mention it had been on watchdog when asking about it
Offline masemk5
« Reply #29 on: December 29, 2013, 09:00:36 pm »
It recently had a service and had new brake discs and pads and caliper on rear.  Then I had to go back because the front caliper seized and they needed replaced and pads on front too.
You think any of that could be linked?  Am gonna go arrange for someone to see it tomorrow.  But am not sure about the garage who done the service as Ive spent £1000 there since the service a month ago on new parts and labour and still needing to go back for more work!
Also the car is a bit slow to start on cold mornings, I wondered if the battery might be needing replaced and that could be linked, no?
Suppose these are questions to tell someone who looks at it!  but good to be armed with a bit of knowledge beforehand
« Last Edit: December 29, 2013, 09:05:51 pm by masemk5 »
