Author Topic: 2008 Standard Headunit - how many speakers  (Read 1213 times)
Offline john87
  • -Receive: 53
« on: September 19, 2011, 09:52:11 am »
When I was in the dealers, I leafed through a mk5 brouchure and noticed it mentioning a '10 speaker audio system' as standard on the GTI. However I've noticed in mine, there are only 4 speakers in the front as opposed to the 6 I was expecting...what's the consensus?
cheers John
Offline johnhol78
Re: 2008 Standard Headunit - how many speakers
« Reply #1 on: September 19, 2011, 03:31:12 pm »
cheers John
Based on mine - 55 plate
6 in the front...t10 in the door and the tweeters..
4 in rear doors......amp under passenger seat.
This is the soundpack upgrade - think the standard is 8 speakers.
Offline john87
  • -Receive: 53
« Reply #2 on: September 19, 2011, 07:06:33 pm »
thanks for the reply  :happy2: I believe I've also discovered the unit does not play WMA's?  :confused:
Offline alexperkins
  • -Receive: 99
« Reply #3 on: September 20, 2011, 01:24:54 pm »
10 was standard with an MFD2/RNS510, otherwise you had to pay for the upgrade
Standard fit normally is 8 (2 in each door)
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #4 on: September 21, 2011, 12:00:36 pm »
early cars all had the 10 speakers then the switch to MY06 saw the reduction unless as Alex says you have the Nav units.
