Author Topic: How to - Remove the rear seat.  (Read 21881 times)
Offline tony_danza
  • -Receive: 112
« on: April 01, 2009, 01:17:15 pm »
Tools:
T30 Torx bit (6 pointed)
10mm Spline drive (12 pointed)
Wiggling arm
10 minutes of your time.
Why?
You might want to swap interiors.
Whole seat weighs 28.3kg, saves weight on track days etc.
Incidentally, the spacesaver is 14kg and the toolkit 5kg.
Method
1. Remove Isofix plastic thingies, note the shape of the grooves in the picture, you have to press down and pull them out rotating the back/top towards you.
2. Remove base, there's spring clips on the front, so feel for their location to ensure you pull in the right place. There's also some more clips towards the sides as shown. It should now pull towards you. Get your fingers under the bit near the Isofix bars to free them up, if necessary.
3. Lay the seat backs flat and using the 10mm spline, remove the seatbelt anchor.
4. Remove the plastic cover for the middle hinge and undo the screw with the T30 Torx bit, then remove the black metal cover it secures.
5. Pull the seats off the pins on the side of the car as shown... this is where you need the wiggle and it has to be the right angle.
« Last Edit: April 01, 2009, 01:22:06 pm by tony_danza »
Sideways yo!
Re: How to - Remove the rear seat.
« Reply #1 on: April 01, 2009, 01:42:22 pm »
Can't ask for much more than that! Top Man  :happy2:
Offline illyun
« Reply #2 on: April 01, 2009, 03:55:52 pm »
Brilliant write up there  :happy2:
« Reply #3 on: April 01, 2009, 04:09:27 pm »
 :drinking: Brilliant write up, top man  :happy2:
Offline tony_danza
  • -Receive: 112
« Reply #4 on: April 01, 2009, 04:30:58 pm »
No problemmo!
However, my exhaust is rowdy as hell now with no sound baffling interior  :party:
Sideways yo!
Offline mixit
  • NEVER GROW UP
« Reply #5 on: April 01, 2009, 04:45:29 pm »
Top Job, thanks for that Tony, should save a lot of head scratching. Nathan, do you have the little Torx jobbies?  :smiley:
« Reply #6 on: April 01, 2009, 07:23:06 pm »
Sure do Mick  :happy2:
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #7 on: April 01, 2009, 08:06:03 pm »
50kg for that little lot  :surprised:
nice writeup tony, great pics , I was there with you  :laugh: :happy2:
Red ED35 5dr DSG
BLOG | BUILD
« Reply #8 on: April 01, 2009, 08:27:58 pm »
Big props that Tony. I love it when some one takes the time out to do a write up like this, to help out fellow dubbers. :drinking: :drinking: :drinking:
« Reply #9 on: April 01, 2009, 08:30:50 pm »
I'll drink to that  :drinking:
« Reply #10 on: April 10, 2009, 11:42:46 am »
Are the fronts the same 10mm spline drive (12 pointed)?
Offline tom866
« Reply #11 on: August 10, 2014, 04:40:34 pm »
 :happy2: :happy2:
Offline JIEEE
« Reply #12 on: August 10, 2014, 07:01:40 pm »
A big thanks will be of use in the near future.
