Author Topic: gt tdi 170 guidance  (Read 1679 times)
Offline gr1zzle
gt tdi 170 guidance
« on: September 21, 2011, 09:05:35 pm »
HELP !
RECENTLY BROUGHT A MK5 GT TDI 170 3DR 08 PLATE DONE 60K.
CAN PEOPLE RECOMMEND PERFORMANCE UPGRADE ADVICE (DO'S AND DON'TS) AS IM LOOKING TO HAVE THE FOLLOWING DONE TO START WITH ?
MAPPED
BRAKES (JUST DISCS AND PADS)
XENON HEADLIGHTS
SAT NAV
ANY HELP WOULD BE GREAT
CHEERS
Offline vRS_Pagey
  • -Receive: 59
Re: gt tdi 170 guidance
« Reply #1 on: September 22, 2011, 06:17:50 pm »
Hi mate, welcome along in yet another diseasel!  :grin:
Definitely go for a remap, 200bhp is easily achievable.  Not sure that you will need to do the brakes, iirc the GT170 has the same set up as the GTi on the fronts anyway - 312mm discs.  Xenons are an excellent upgrade, although to save a few pennies you could upgrade the OE halogen bulbs to something like Osram Nightbreakers or Ring Xenon Max, obviously no comparison to OE xenon, but a lot better than standard.  The sat nav of choice is the RNS-510 or MFD3, especially the later version with LED touch screen.  I have the MFD2 installed in the Golf, it's ok but I certainly wouldn't have paid the £1500 VW wanted as an optional extra..... :surprised:
Some things you may want to do:
GTi rear valance (colour coded)
GTi front spoiler insert
GTi side skirts (colour coded)
LED interior, puddle and sidelights
Tbh the list is endless, and joining this forum is very bad for your bank account!!!!!
Offline PDT
  • -Receive: 142
« Reply #2 on: September 22, 2011, 06:22:24 pm »
If you want a map thats really good, get a stage 2 package that includes DPF replacement pipe. 220+hp and 330 ft/lb is available. without DPF removal power is limited to around 190-200hp and 300 ft/lb due to the limitations required to avoid the DPF clogging and/or regenerating too often.
Offline jabbawocky
« Reply #3 on: September 22, 2011, 08:42:57 pm »
never heard a truer word :signLOL:
Offline gr1zzle
« Reply #4 on: September 23, 2011, 09:28:29 pm »
Looking to get the custom remap done in the next 2-3 weeks .......not the brightest when it comes to this !!
should i get this dpf and a egr deletion valve ?
what about a panel filter ?
