Author Topic: Any ideas? Misfire?  (Read 14151 times)
Re: Any ideas? Misfire?
« Reply #30 on: October 01, 2011, 09:06:09 pm »
John_o had similar symptoms which were caused by faults in APR sofware, discovered and rectified by Awesome Gti...
Offline Weston
« Reply #31 on: October 01, 2011, 09:08:01 pm »
Have you approached them about this fault as yet?
Not at the moment, I think I probably should get in touch
GTI going...
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #32 on: October 01, 2011, 10:37:41 pm »
Can you log individual injectors...?
Diesel Daily Hack.
Offline Weston
« Reply #33 on: October 02, 2011, 11:51:30 am »
Possibly. Had it checked for codes, intermittent misfire cylinder 3 & intermittent random / multiple misfire.
I've borrowed the thing so I should be able to do some live logging & reproduce the misfire
GTI going...
« Reply #34 on: October 02, 2011, 11:56:07 am »
Same faults as mine it's like a tfsi virus!
Offline Weston
« Reply #35 on: October 02, 2011, 12:01:28 pm »
Hopefully it's just cylinder 3. Might gave to swap the plug & coil pack with another and see off the fault moves
GTI going...
« Reply #36 on: October 02, 2011, 12:05:00 pm »
That's what I did yesterday and it stayed on cyl 3 :(
Offline Weston
« Reply #37 on: October 02, 2011, 04:52:56 pm »
Just done some logging. Noticed for knock sensor voltage cylinder 1, 2 & 4 were all 0.156 V and cylinder 3 was 0.312 V. Could this be my issue? Are there separate knock sensors?
GTI going...
Offline vRSAlex
  • -Receive: 253
« Reply #38 on: October 02, 2011, 06:44:54 pm »
There are only 2 knock sensors.
Follow AKS tuning on Facebook
Offline Weston
« Reply #39 on: October 02, 2011, 08:22:37 pm »
That's odd then :confused:
GTI going...
Saint Steve
« Reply #40 on: October 02, 2011, 08:25:05 pm »
Sounds like cylinder or valve trouble to me
Offline Weston
« Reply #41 on: October 02, 2011, 08:36:06 pm »
What should I check for / replace Steve?
GTI going...
Saint Steve
« Reply #42 on: October 02, 2011, 08:48:24 pm »
Compression test, to check for 4 uniform compression readings, maybe a rouge spark plug out of the set you bought back in march .
Have you taken the plugs out to see the colour of them?
Unlikely to be an injector if your getting knock sensor imbalance IMO.
Offline R-tech-Nick
  • -Receive: 30
    • R-Tech Performance Tuning
« Reply #43 on: October 03, 2011, 01:29:01 pm »
Hello,
I dont thik It will be the remap code as I have not had any issues in the past, but the map and getting the car on full power by fixing the PCV could have highlighted under laying issues, as part of the r-tech remap map we do offer customers a life time of ownership help and advice, in return for a packet of hobnobs each time. :grin:
You more than welcome to pop to us for a foc loging session on the dyno, which should help point you in the right direction.  It could be a coil pack (even the new ones give up easy)  Once its on the dyno I can easy check the fuel and ignition out in around 30 mins, plus we have plugs and coil packs in stock which we can trial and error test with.   Just drop Jim a line at the workshop and he will find a slot which is good for you.
Nick R-Tech
01455 617233
Offline Weston
« Reply #44 on: October 03, 2011, 02:44:57 pm »
Hello,
Nick R-Tech
Cheers Nick I was gonna give you a call anyway. Just rang up and was told anytime Monday will be fine so I'll come up then, probably be there around 11  :happy2:
Chris
GTI going...
