Author Topic: DIY wheel refurb'  (Read 5310 times)
Offline vRS_Pagey
  • -Receive: 59
DIY wheel refurb'
« on: September 25, 2011, 09:38:28 am »
I've been planning on getting my 18" Zeniths refurbished however after fitting a new set of wheels to the marauder, I have decided to have a go at the job myself.  Tbh 3 of the wheels weren't that bad, light kerbing and lacquer flaking, however 1 was quite badly damaged, not to be put off I attacked them with a random orbit sander, and a file!   :scared:
After cleaning them up with some household cleaners and a nasty concoction of chemicals from the garage, repairing the damage with body filler and sanding I was left with the following -
Unfortunately 2 of the tyres have quite substantial rim guards so I will need to crack the bead to be able to paint them correctly, the other 2 aren't as bad, so I masked them up and gave them 2 coats of primer.  Once dry I gave them both a light rub down with 1200 grit wet and dry.  This left the following:
So far so good, now to decide on colour, OE silver or slightly darker?  I was going to go anthracite, but to go that dark I would need to refurb the entire wheel, not just the face.
Offline parks
  • Red ED30 No. 1778 Detailing World member
Re: DIY wheel refurb'
« Reply #1 on: September 25, 2011, 09:42:07 am »
top effort, well worth a try for the saving!!
Standard: Rear parking sensors, Parrot Bluetooth
Retro fitted: MFSW buttons, RCD510, Boot pop, Black Monza II, Xenons, Audi jacking points, open fog light grills.
Offline vRS_Pagey
  • -Receive: 59
« Reply #2 on: September 25, 2011, 09:47:44 am »
So far it has cost 10 quid, that's for a roll of 2" masking tape and a 500ml tin of grey primer which I got from Partco as the nozzle gives a far superior spray pattern than Halfrauds carp!  I will probably need a 2 second tin to complete the job and to prime the GTi side skirts I am getting for swmbo's Golf GT.  I will get the paint mixed at a specialists and an aerosol filled, for this and a couple of cans of lacquer I would estimate a further £35-£40.  So total cost of refurb (not including my time) 50ish quid.  :happy2:
Offline RSam84
« Reply #3 on: September 25, 2011, 01:36:31 pm »
i did the same when i owned my Rs turbo, looks like your doing a really good job!
Offline Weston
« Reply #4 on: September 25, 2011, 03:11:48 pm »
I'd be interested to see the final result. I was gonna get my winter wheels refurbed but can't justify it. This might be a good option  :grin:
GTI going...
Offline vRS_Pagey
  • -Receive: 59
« Reply #5 on: September 25, 2011, 04:15:48 pm »
The irony is, I was going to practice on my 'expendable' winter alloys first, I must of had a moment of madness to attack the Zeniths..... :scared:
Offline vRS_Pagey
  • -Receive: 59
« Reply #6 on: September 28, 2011, 05:20:28 pm »
Small update, I have now cracked the beads on both offending tyres.  All 4 wheels are now fully repaired and primed.  On to the decision, as the wheels will be going back on the car as part of a 'return to standard' exercise when it comes to selling (long way off), I have decided against a full blown colour change to anthracite, but I would like to go slightly darker than the OE silver, can anyone give recommendations on suitable colours to try, preferably with a code to get the paint mixed?
Cheers, Lee.
denis
« Reply #7 on: September 28, 2011, 06:17:25 pm »
just go into a paint/bodyshop suppliers and ask to look at the colour chips
Offline Weston
« Reply #8 on: September 28, 2011, 07:10:24 pm »
How long has it taken to get to this stage?
GTI going...
Offline vRS_Pagey
  • -Receive: 59
« Reply #9 on: September 29, 2011, 01:17:36 pm »
Total 'my time' not including cracking the beads on 2 of the tyres, I would estimate........3-4 hours max.
Offline daboy3000
  • MKV GT TDi
« Reply #10 on: September 30, 2011, 03:37:13 pm »
What filler did you use and when using the sander what time of abrasive did you use?  I know nothing about orbital sanders but I'm going to attempt to do a two tone refurb on mine soon.
denis
« Reply #11 on: September 30, 2011, 03:51:25 pm »
on alloys its best to use a metal based filler, not normal body filler
on sander you want to use around 180-400 grit discs/pads, can be bought cheap from motor factors/bodyshop suppliers, or even screwfix
Offline daboy3000
  • MKV GT TDi
« Reply #12 on: September 30, 2011, 04:21:28 pm »
Stupid question but is this normal sand paper or one for metal?
denis
« Reply #13 on: September 30, 2011, 04:54:17 pm »
most sand paper can be used on everything, but don't buy cheap crap because its useless
Offline vRS_Pagey
  • -Receive: 59
« Reply #14 on: September 30, 2011, 05:15:53 pm »
Tbh I just used normal body filler, but the amount required was minimal, I used 240 grit normal (wood) sand paper attached to my sander, some bits needed hand sanded, for this I used 150 grit, to flatten back the primer I used 1200 grit wet and dry and when I flatten the lacquer prior to polishing I will go with 2000 - 3000 grit wet and dry.
