Author Topic: Aux Retro Fit ....  (Read 4067 times)
Offline impuLz
  • PUGPOWAA
Aux Retro Fit ....
« on: September 25, 2011, 05:21:09 pm »
Hello, had a look around the search function but was unable to find anything about this so figured a simple ask is best.
I have been interested in getting an AUX IN installed via VW as part of the £100 accessories voucher i was given, upon asking they said it would be installed in the glovebox (sure thats where i want it .... not) and once it is fitted my Glovebox light will no longer work (also fail on their part) ... so i said i would think about it...
any chance anyone has a 'how to' guide on fitting this into the centre armrest/ lower console (near gear stick) as thats where i would like to have it - and would it be workable with the light on glovebox not having to be disabled?
cheers in advance!
James
Nothing Logical to Enter
Offline impuLz
  • PUGPOWAA
Re: Aux Retro Fit ....
« Reply #1 on: October 10, 2011, 09:07:19 pm »
any help please lads?
or even a link to a guide that i missed?
thanks!
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=qi54ite2h2rgbiu5n0e83pskdj&/topic,19740.0.html
« Reply #2 on: October 10, 2011, 09:24:56 pm »
What radio is it?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: October 10, 2011, 09:46:34 pm »
Hi
I'm working on a retrofit loom and socket for the armrest for Golfman.
As soon as it is done, I will add more info.
Cluster and Key coding
Location Great Yarmouth
Offline parks
  • Red ED30 No. 1778 Detailing World member
« Reply #4 on: October 10, 2011, 10:08:53 pm »
Hi
oooo interested... am listening!!
Standard: Rear parking sensors, Parrot Bluetooth
Retro fitted: MFSW buttons, RCD510, Boot pop, Black Monza II, Xenons, Audi jacking points, open fog light grills.
Offline MitchGTI
« Reply #5 on: October 12, 2011, 06:28:19 pm »
as for fitting a aux socket in the glove box, what cable do you need to buy to put it in there? im going to get a rcd510 and wanted the aux function but i havnt got in in my arm rest obv
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #6 on: October 12, 2011, 06:34:17 pm »
you can fit anywhere you like, as long as you can cut a slot for the socket
Offline MitchGTI
« Reply #7 on: October 12, 2011, 06:47:12 pm »
 rite im not to fussed about having a little hole in the glove box! is there a cable i have to buy to connec to the head unit?
cheers! mitch
Offline impuLz
  • PUGPOWAA
« Reply #8 on: October 12, 2011, 08:03:43 pm »
this is with the most basic model of radio, RCD310 ? or along those lines, not bothered by getting a better headunit
but if i ask VW to change where they fit it will it still result in lack of glovebox lighting?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #9 on: October 15, 2011, 07:06:36 pm »
Loom made and working with RNS510 :happy2:
So this retrofit should work with RNS & RCD510 and RCD310
I will be making an add-on to the MDI kit so you can have AUX-in too. Which is good if you have a C or D version as that will clear the Open circuit fault
Info and pics soon in
http://www.mk5golfgti.co.uk/forum/index.php/topic,23583.0.html
Offline golfman
  • -Given: 17
« Reply #10 on: October 16, 2011, 07:00:13 pm »
AUX for the RNS 510 and RCD 510/310
EddieNL can make up the loom and supply the button so all you have to do is make a small hole for the AUX in your armrest or to be honest you can put this anywhere
the other end of the loom(Blue plug) goes into the big stereo plug and there is only one place it can go then code it in your radio or navigation for AUX and then on the RNS you just tick the box for AUX and you are good to go :happy2:
scott
Vag-com Hex+Can in scotland
I Hate Timewasters...
Offline MitchGTI
« Reply #11 on: November 17, 2011, 08:10:48 pm »
bring this back up from the dead! i have pruchased a rcd510 now and want the aux in what do i need to buy??? to have the above?
thanks in advance!!
