Author Topic: How to retro fit cruise control. Comprehensive guide  (Read 108213 times)
kisyov
Re: How to retro fit cruise control. Comprehensive guide
« Reply #30 on: March 21, 2019, 04:48:17 pm »
Hello friends, I need help. I have VW Caddy Maxi 2009 /same as golf mk5/, after retrofitting cruise control and MFSW , horn stop working and the buttons of SW Not working. I change my control module from mid line to highline /from 1K0-953-549-CQ to 1K0-953-549-CF /. From Ross-Tech website I saw that my Slip Ring is Type 2. I think, I did everything right, but only cruise control working, no buttons and no horn.
Parts I use.
1Q0 419 091 KUSZ – Steering Wheel / 17.11.2007 /
1K0 971 584 N – airbag harness / original harness from my not MFSW is same without N /
2k0 880 201 L 10QB -  Airbag from my original SW
1k0 959 538 F – MFSW buttons
1P0 959 542 – MFSW control unit
1K0 953 549 CF – Control module
1K0 953 513 G – Cruise control stalk
Wipers stalk I didn’t change, it is with trip button.
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
   Component: J0527           055 0111
   Coding: 0000534
   Shop #: WSC 01357 011 00200
   VCID: 78FF0E6B0B2690DEAC3-802D
1 Fault Found:
01426 - Controls in Steering Wheel (E221)
            004 - No Signal/Communication
I thought that My SLIP RING NOT working, after I put my old airbag harness from non MFSW and recoding the Control Module,  horn start working and cruise control, too. So my SLIPRING is OK.
So what is wrong , where is my mistake? I want my MFSW to work. I this to change airbag harness, please suggest model.
Offline martinatfc
« Reply #31 on: April 07, 2019, 07:27:36 pm »
Can someone do mine for me?
I have a 2005 Golf GTI Mk5.
Cash up for grabs obviously.
My DIY skills are useless.  :fighting2:
I'm based in Farnham, Surrey or Aldershot, Hampshire.
Offline Octoparrot
  • -Receive: 102
« Reply #32 on: April 07, 2019, 09:30:45 pm »
Do you know if you have the extra wire fitted?
Offline kevster996
« Reply #33 on: May 04, 2019, 12:55:03 pm »
I just updated my stalk to cruise control and updated the steering wheel control module to the CH version (new one off ebay). I have fitted an MFSW now but not coded yet. Now when I start up the right hand indicator goes all the time and using the stalk makes no difference?
I need to do the power steering reset as Ive lost this now too? My car is a 55 tdi 4motion - I wonder if I need to get a different slip ring? I'll check the part number. Bit dangerous to drive with indicators turning right all the time!
Parts I have:
- Cruise Control Indicator Stalk Arm OEM 1K0 953 513 F (wrong one?) (old one 1K0 953 513)
- slip ring 1K0 959 653 C (should ok with steering wheel module?)
- new steering wheel control module 1K0 953 549 CH off ebay (should work with my slip ring)
I need to wire in the extra wire to the ecu for CC - its only half done
Ive put the old stalk back on for now and its sorted the indicator issue...
« Last Edit: May 05, 2019, 12:21:01 pm by kevster996 »
Golf 5 2005, 2.0 TDI 4motion, remapped to 175bhp, lowered on eibach springs, GTI front end, GTI half leather interior
Offline ljc19630
« Reply #34 on: May 08, 2019, 06:50:00 pm »
Niceeee
Offline kevster996
« Reply #35 on: May 09, 2019, 07:01:33 pm »
Parts I use.
   Coding: 0000534
1 Fault Found:
did you fix this yet? i have similar problems on my 2005 tdi 2.0 - I need to get VCDS on it I think. I have CH module not not CF like yours and a midline display. I dont have power steering either right now since I changed the module! I have found a local guy who can have a look - he is about £60 an hour but can prob do lots in one hour... I hope I dont need a different module.
