Author Topic: Estimated power gti  (Read 3738 times)
Offline b21playa
Estimated power gti
« on: September 29, 2011, 06:25:41 am »
With carbonio intake, forge twintercooler , miltek sports cat and cat back and superchips. RemAp?
Offline gazon69
Re: Estimated power gti
« Reply #1 on: September 29, 2011, 08:58:42 am »
Depends whose rollers they go on. Being generous 275ish not so generous 250ish. If its more oomph you want then personally i wouldn't bother with the carbonio intake, i would go for either an evoms, itg or forge twintake as they are meant to give you the better gains. Just remember when you go that far up in power though that you will more than likely have to make other changes to cope with the extra power e.g brakes, suspension,  arb's, walk. The lists can be endless, but then thats why we're here .  :signLOL:
Offline b21playa
« Reply #2 on: September 29, 2011, 09:05:38 am »
What plugs would be best suited for this?
Offline JackG
  • -Given: 33
  • -Receive: 31
    • Distinct Detailing
« Reply #3 on: September 29, 2011, 09:13:54 am »
Down you go!!! Slippery slope of modding, it will take over you  :signLOL:
www.distinctdetailing.co.uk
« Reply #4 on: September 29, 2011, 09:24:25 am »
238 BHP ish .  :happy2:
Offline T J Hooker
« Reply #5 on: September 29, 2011, 12:09:22 pm »
I have 239.8bhp and 255ftlb with a forge twintake and custom map only. Surely he should see more?
2005 Mk5 GTi DSG, TDR Performance Custom Map, Forge Twintake, Yellow Lamin-X Fog Light Tints, H&R Cup Kit, R32 Rear Lights, BSH Stage 1 PCV Fix.
239.8bhp / 255.8 ftlb
Offline Ducky76
« Reply #6 on: September 29, 2011, 12:25:49 pm »
I got 215 with 250 torque, neuroses p flo and custom code stage1 mollusk cat back !!  :confused:
Offline baldwined30
« Reply #7 on: September 29, 2011, 12:52:23 pm »
Stick with OEM plugs! Dont waste your money on the carbino intake!! they do zero for performance!!!
Ed30
Offline vRS_Pagey
  • -Receive: 59
« Reply #8 on: September 29, 2011, 01:05:04 pm »
Either the rollers were shockingly inaccurate, or you've been had!  :scared:
A stage 1 remap only will typicially yield between 235/40 BHP, stage 2 varies depending on intake and down pipe fitted whether it be sport or de-cat, but ball park figure 260 BHP, then on the 270/80 BHP for stage 2+ with the addition of intercoolers HPFP's etc.  but all this is irrelevant imho, figures are for pub talk, real world driving is what counts.  :happy2:
« Last Edit: September 29, 2011, 01:08:53 pm by vRS_Pagey »
Offline Ducky76
« Reply #9 on: September 30, 2011, 11:49:23 am »
Quote from: Ducky76 on Yesterday at 12:25:49 pm
I'm going back 2 day see what they say but something not right for 360££
Offline T J Hooker
Re: Re: Estimated power gti
« Reply #10 on: October 11, 2011, 10:51:51 am »
Did you get this sorted?
Offline Ducky76
« Reply #11 on: October 12, 2011, 08:39:02 pm »
Well I've been told it's correct by jbs they had it for a hour rechecked it took it out for a drive and said they don't aggree with rolling road result so basically just drive it , it is faster than before but I did get dv done at same time old one was split so dunno , one thing is sure il not be spending any more money there
Offline mrtrendvampire
« Reply #12 on: October 13, 2011, 12:44:35 pm »
my standard gti engine is crazy, if it got any faster i swear i would travell back in time, why do you need it faster?
Offline Ducky76
« Reply #13 on: October 13, 2011, 09:09:10 pm »
Just because :driver:
Offline R-tech-Nick
  • -Receive: 30
    • R-Tech Performance Tuning
« Reply #14 on: October 13, 2011, 09:59:58 pm »
Its all about the area under the curve, you could end up with the same peak bhp of 238bhp but have around 40bhp more power average under the power curve.
I would be happy with seeing around 255bhp-290lbft with a wide torque curve on my dyno with your mods and the sc remap to complement them, then with HPFP and mapping 275-280bhp
The car in the link below aint got huge peak numbers due to power to weight ratio rules, 240bhp 275lbft but the torque band is very wide and holds on to the peak power for a lot longer making this car a rocket and winning races... :happy2: Its running similar engine mods.  http://i258.photobucket.com/albums/hh252/Rtechremaps/IMG_0997.jpg
« Last Edit: October 13, 2011, 10:02:35 pm by R-tech-Nick »
01455 617233
