Author Topic: Bonnet insulation  (Read 14185 times)
Offline Little_Dave
Bonnet insulation
« on: September 29, 2011, 08:03:24 pm »
Mines been loose for a while now almost as if i've lost some clips are fasteners?? Are these easy to get hold of as it's annoying everytime i lift the bonnet to have to poke the bottom edge of the insulation back into the slots  :fighting:
Dave
Offline parks
  • Red ED30 No. 1778 Detailing World member
Re: Bonnet insulation
« Reply #1 on: September 29, 2011, 08:17:24 pm »
not 100% sure i have insulation under my bonnet??
Standard: Rear parking sensors, Parrot Bluetooth
Retro fitted: MFSW buttons, RCD510, Boot pop, Black Monza II, Xenons, Audi jacking points, open fog light grills.
Offline QD MBE
  • -Receive: 102
« Reply #2 on: September 29, 2011, 08:24:22 pm »
Bonnet insulation - 1K0 863 831 D - £42 ish
Clips - 1H5 863 849 A 01C (10 required)£1 each ish
Offline Little_Dave
« Reply #3 on: September 29, 2011, 08:29:50 pm »
Thanks QD  :drinking: very much appreciated, i had no idea how many i should have and so how many i'd somehow lost  :happy2:
Dave
Offline mortygttdi
  • -Receive: 146
« Reply #4 on: September 29, 2011, 08:45:10 pm »
If you look under the bonnet you should be able to see a load of square cutouts? these are what you have lost :happy2:
Darren
Offline Little_Dave
« Reply #5 on: September 30, 2011, 12:14:01 am »
Darren
Thanks Darren i'll have a look in the morning and see how many i need to get  :smiley: its only the rear left corner of the insulation near the wipers that hangs down and needs tucking in when i open it up
Dave
« Last Edit: September 30, 2011, 12:15:41 am by Little_Dave »
« Reply #6 on: September 30, 2011, 08:43:45 am »
When I had a steel bonnet some good friends of mine (The BIALI Boyz) decided to remove mine!
« Last Edit: September 30, 2011, 08:45:20 am by RedRobin »
Offline Little_Dave
« Reply #7 on: September 30, 2011, 01:30:56 pm »
Isn't it there for a reason tho?  :laugh: thought it reduced the amount of heat  warming up the bonnet and so protecting the paint?  :confused:
Dave
Offline mortygttdi
  • -Receive: 146
« Reply #8 on: September 30, 2011, 02:30:19 pm »
Its actually a sound deadening material :happy2: only there to quieten the engine down :evilgrin: you don't need it
Darren
Offline andy7ven
  • -Receive: 30
« Reply #9 on: September 30, 2011, 02:59:10 pm »
I'm not missing any clips on mine but its always hanging out up by the washer jets everytime the bonnet is opened no matter how many times it's been tucked back in.
Offline big al
« Reply #10 on: September 30, 2011, 03:47:37 pm »
I removed mine too, it was sagging, so took it off, looks much nicer without. :smiley:
« Reply #11 on: September 30, 2011, 05:25:24 pm »
Darren
....The perfect reason to remove it!  :happy2:
Offline vRS_Pagey
  • -Receive: 59
« Reply #12 on: September 30, 2011, 06:53:00 pm »
I didn't have it fitted on the vRS so it clearly isn't for heat protection, and after I did fit it I wish I hadn't as you can't hear the intake as well...... :sad1:
I have it on the diseasel GT as well, and it makes a lot of difference to the engine noise, it sounds like a tractor with the bonnet up.  Tbh it sounds like a tractor with the bonnet down, just one parked a bit further down the road!  :laugh:
Offline Little_Dave
« Reply #13 on: September 30, 2011, 09:13:44 pm »
Thats exactly what mine does but i thought i had some clips missing but when i looked they are all there but its sagging all droopy draws  :laugh: some of the filling is hanging out too so looks terrible, might remove mine then and if my car sounds too loud i can always get a replacement in the future  :happy2:
Dave
Offline brough74
« Reply #14 on: October 01, 2011, 08:32:53 pm »
It can be removed easily but better for noise insulation, but if you want a clean bonnet, it needs a bit of graft
PEARL DIAMOND BLACK 3dr GTI
HEATED LEATHER,MULTI FUNCTION WHEEL,
18” MONZA ALLOYS, XENON HEADLIGHTS, FLAT TYRE INDICATOR
LUX PACK AND WINTER PACK
SHARAN AERIAL, GTI TAX DISC HOLDER, R32 REAR LIGHTS
VW RACING FRONT SPOILER
