Author Topic: MFSW < FINAL UPDATE - Pictures  (Read 1855 times)
Offline Johnny_tro
« on: October 01, 2011, 11:35:31 am »
Right, as certain people will know having a right nightmare....!! Question being WHERE DO I GO TO GET THESE BUTTONS ACTIVE read up and just  :rolleye: mind f**king me....
Right here goes........
My clocks
The airbag
The Wiper/Indicator stalk and slip ring
The Controller (or if you use your imagination, the view from the rear seat of a jet fighter  :grin: )
The Wheel
« Last Edit: October 01, 2011, 11:49:07 am by Johnny_tro »
Offline mortygttdi
  • -Receive: 146
Re: MFSW < FINAL UPDATE - Pictures
« Reply #1 on: October 01, 2011, 01:18:52 pm »
The buttons will never work mate :sad1: this is the thing we was on about not so long ago, the clocks are too old and will only work with either the stalk or the older button set with the 2 phone buttons and the source button.
Unfortunately this scuppers our plans of swapping :confused: has they will not work in my car I would have the same problem has your having.
Kalu was on about this to me before and basically the early clocks only have 3 bytes for the buttons ie volume up/down, phone hangup/answer and the okay button the later clocks had 4 bytes the added byte was to control the menu button.
Darren
Offline Johnny_tro
« Reply #2 on: October 01, 2011, 03:26:49 pm »
? Not at all?
For this to happen would it not be a case of
Slip ring
Controller
Loom
and new clocks
Or are you saying simply.......NO go regardless?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: October 01, 2011, 03:34:20 pm »
If you fit the following
C version Slip ring
Highend controller
Mfsw / Airbag loom
you will have a working multifuntion steering wheel
The Menu Button won't work, just use a long press on the UP button to change settings
Audio and Navigation menus (to get out off you will need to switch the Radio off)
The phone button won't work if you don't have the phone kit
Cluster and Key coding
Location Great Yarmouth
Offline Johnny_tro
« Reply #4 on: October 01, 2011, 04:07:51 pm »
So the only way to get this FULLY working < to replace the clocks as well? is this the issue?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #5 on: October 01, 2011, 05:17:00 pm »
Yes, are you so desperate for a working menu button.
972 clocks are very rare
I recently fitted some, and the guy went to VW to buy then new for £426 :scared:
Offline Johnny_tro
« Reply #6 on: October 01, 2011, 06:40:27 pm »
Am I desperate? no........but if I do things I do like to do it properly  :sad1:
but gutted really, as was told wheel etc would would well with the car.......
Conv. Menu < is this also affected by the clocks I have?
Although I ave lot of stuff on my car < its pretty entry/basic level parts ?
« Last Edit: October 01, 2011, 06:47:42 pm by Johnny_tro »
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #7 on: October 01, 2011, 09:11:51 pm »
The wheel will work with your car, just not the menu button.
you will have control over the volume, access the trip computer, change CD tracks
but you need
1x Slip ring C
1x Highend Steering controller
1x MFSW / Airbag loom
if you want the menu button then you need to change your clocks to ones ending 972
Convenience option in highline is only available if you fit MAX CCM
1K0 959 433AR or 1K0 959 433CB
All of the info you require is in this post, please do not keep posting asking what you need
