Author Topic: iPod dock in armrest advice  (Read 903 times)
Offline crashdesk
  • -Given: 35
« on: October 01, 2011, 04:23:26 pm »
I have this in my armrest and assume it's for an ipod nano.
https://skitch.com/clintonbeattie/f7qtt/preview
Has anyone here got a similar one? I don't have an ipod nano and don't kno which version of the nano will fit. I would really like to use my iphone as I don't want to buy another bit of tech but if there I find a nano cheap enough with enough memory to hold most of my tunes it would be handy. I could just leave it in there all the time.
Also, when it is connect can I control it through the standard GTI stereo?
Thanks for any advice or tips.
Best,
C
Offline Nodz
  • -Given: 73
  • -Receive: 103
Re: iPod dock in armrest advice
« Reply #1 on: October 01, 2011, 04:34:14 pm »
I've got this and run my 4th gen nano through it. It will run any ipod iirc, the iPhone is a tight fit and I think you might get interference aswell (from it finding signal) which is why i don't use my iphone.
It works as the 6 cd changer, press cd twice to get the six "discs" showing. It then will have the 1st five playlists from your ipod loaded as disc 1 - 5 and then the 6th disc is 99 random songs from your ipod. Also it will only play 99 songs from each playlist it has loaded on discs 1 - 5 as this is the limit.
Hope this helps  :happy2:
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #2 on: October 01, 2011, 05:15:18 pm »
If I were you I'd look for a slightly older ipod as apple changed the way the newer ipods charge (swapped to or from firewire pin to something else) and as a result the newer ipods will work but won't charge via the dock.  A minor nuisance and there are convertors on ebay.
Sepang Blue S4 BE Avant
Offline crashdesk
  • -Given: 35
« Reply #3 on: October 01, 2011, 07:17:08 pm »
Yeah, definitely no way iphone will fit :-(
Will look for an older gen nano. Will check around at my work to see if someone owns one.
Thanks!
