Author Topic: Downpipe fitting  (Read 3185 times)
Offline vRS_Pagey
  • -Receive: 59
Downpipe fitting
« on: October 04, 2011, 08:43:12 am »
Can anyone confirm that if I fit a milltek downpipe with sport cat while running stage 1 software, could it potentially damage the engine if I run it for a few months before having the software tweaked?
Offline PDT
  • -Receive: 142
Re: Downpipe fitting
« Reply #1 on: October 04, 2011, 09:26:59 am »
As per my PM, you will be fine  :happy2:
Offline daboy3000
  • MKV GT TDi
« Reply #2 on: October 04, 2011, 09:36:26 am »
Could you explain more about this as I wasn't thinking I would need to spend another £300 on a remap
« Reply #3 on: October 04, 2011, 11:44:33 am »
iirc RedRobin had the milltek TBE fitted on his car whilst still stock i.e. no remap and ran it like that for many months without any problems.
Offline gazon69
« Reply #4 on: October 04, 2011, 06:16:32 pm »
I had evoms intake milltek tbe and a few other bits on mine before going straight to stage 2+ and had no problems whatsover.
Offline vRS_Pagey
  • -Receive: 59
« Reply #5 on: October 04, 2011, 06:58:53 pm »
If you already have stage 1 your tuner will normally charge upto £100 to upgrade your software to stage 2.  I am having issues as my tuner doesn't do staged tuning.  They can tweak the map to allow for the added flow from the sport cat etc, but I will need to complete a 450 mile round trip for the privilege.
Offline gazon69
« Reply #6 on: October 05, 2011, 11:41:46 am »
I didn't have stage 1 pal. I fitted a few of the bits myself than ran it like that for a couple of months until i got a bit more money saved for other bits, then straight to a stage 2+ map
Offline vRS_Pagey
  • -Receive: 59
« Reply #7 on: October 07, 2011, 09:38:37 am »
Next question on the fitting, the Milltek is 70mm diameter compared to 60mm OE pipe (on the vRS), whats the best way to fit the reducer?  I was thinking about having it welded to the downpipe but clamped to the OE cat back, that way it will be easier to return to standard.  Any thoughts or examples would be good?
« Last Edit: October 07, 2011, 02:29:57 pm by vRS_Pagey »
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #8 on: October 07, 2011, 10:56:18 am »
My Pipewerx has a special reducer pipe from the 3" down to the standard at the cat back...
Diesel Daily Hack.
Offline vRS_Pagey
  • -Receive: 59
« Reply #9 on: October 07, 2011, 02:30:24 pm »
That doesn't help...... :P
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #10 on: October 07, 2011, 02:51:51 pm »
Would a pic? ;-)
Diesel Daily Hack.
Offline muckipup
  • -Receive: 25
« Reply #11 on: October 07, 2011, 03:31:10 pm »
Hey Lee, I have the Pipewerx as well so didn't need a reducer either but the reducers can be got of the internet. Welding seems like a bit of unnecessary work when the reducer with a couple of good clamps and some Hylomar to keep the jointing gas tight would do.
Offline vRS_Pagey
  • -Receive: 59
« Reply #12 on: October 07, 2011, 03:55:30 pm »
Sounds like a plan!  I just don't want an permanent items attached to the OE cat back.  :happy2:
Offline martziniuk
« Reply #13 on: October 07, 2011, 09:38:17 pm »
I had a cone reducer welded onto the DP and a length of 2 1/4" pipe welded onto that. I think the gradual reduction via the cone is a good way to do it.
« Last Edit: October 07, 2011, 09:40:54 pm by martziniuk »
Offline vRS_Pagey
  • -Receive: 59
« Reply #14 on: October 07, 2011, 10:53:06 pm »
When I fitted the GTi back box on swmbo's Golf I used a step down reducer and clamps, I didn't use sealant either and it seems fine.  I just wanted something a bit more professional this time.
