Author Topic: N75 Replacement - But I have Forge DV... UPDATE  (Read 16357 times)
Re: N75 Replacement - But I have Forge DV... UPDATE
« Reply #15 on: October 08, 2011, 09:40:45 am »
When I did a google search yesterday all that came up where on the turbo.  So have they essentially told you your part is fine it will fit on the rear.  maybe forge are using a TDI part for some sort of pressure sensor so the ECU knows what the forge DV is doing? i.e if it is open or closed?
I think it's to do with it being vacuum operated not electronically?
The N75 near the turbo too much of a ball ache to change on the driveway?
Offline Richn83
  • -Given: 49
  • -Receive: 86
« Reply #16 on: October 08, 2011, 09:44:58 am »
maybe go out for a drive and see if you can log the N75 duty cycle and the DV duty cycle along with the boost pressure and mass air flow and see what results you get might help you to know if you need to bothere changing it?
have you got your original DV to hand?  just wondering if its worth re-fitting after logging to do a comparison run?
« Reply #17 on: October 08, 2011, 09:50:20 am »
Original DV is the old diaphragm type & in the Uk, Doh.  I would log & / or nip back to dealer and see if they'll fit it but I'm meant to be taking shelves down ready for moving out  :sad1:
« Reply #18 on: October 08, 2011, 10:02:37 am »
After lookin at this http://www.etuners.gr/eg/index.php?s=12&t=220 (halfway down page)
I won't be able to do it outside the house.
Do I risk putting SWMBO in a bad mood and goin to see I Can get it fitted lol...
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #19 on: October 08, 2011, 10:13:02 am »
Be prepared to get annoyed if you do, they have those special clips on, which might need special tools, replacement ones...
Diesel Daily Hack.
« Reply #20 on: October 08, 2011, 10:37:47 am »
 I wouldn't be surprised if the dealer didn't have them ring clips in stock, they don't seem to hold anything  :fighting:
I'm not attempting it on the drive looking at them clips (& the weather)
« Reply #21 on: October 08, 2011, 04:16:17 pm »
Will have it fitted Mon with smoke test. Waiting for rain to stop so I can pull MAF out.
Replace N75, 90 silicone inlet elbow, MAF check, smoke test this week.
Got REVO & BF decat DP to go on... Need her running right 1st though!
Offline damoegan
« Reply #22 on: October 08, 2011, 09:14:11 pm »
Would you like me to have a check of the p/n of my N75 tomorrow, Mike?
« Reply #23 on: October 08, 2011, 10:45:59 pm »
Thanks for the offer.  Think I've cleared it up. The forge DV uses a tdi valve and I still have the OEM N75 by the turbo with the pn I originally posted.
Going to fit the new N75 as it's in for diagnostics anyway.
Offline damoegan
« Reply #24 on: October 08, 2011, 10:51:57 pm »
No worries matey  :smiley:
Just actualy realised that the N75 actualy comes as part of the Forge DV, it was that long ago since I fitted it  :ashamed:
« Reply #25 on: October 08, 2011, 11:00:52 pm »
You'll find if you unplug the n75 in your pic it will have the groove like the one I posted, Forge apparently use a tdi valve with the DV to allow it to work properly (vacuum operated?)
I will have another valve near the turbo (I'm ko4) that's the one I'll repose seeing as I have a new one sat here now :)
zerrchh
« Reply #26 on: November 27, 2015, 11:15:48 pm »
Did you find out a way to get that N75 valve without the groove to fit? I'm running into that problem. No groove, but I got a Forge DV on my MK5 GTI. In dire need cause I think it's whats causing the problem on my car. Thinking of just trying to manually carve a groove.
« Reply #27 on: November 28, 2015, 09:21:32 am »
Im sorry it was so long ago, I'll re-read my thread and see if it refreshes my memory.
I'm back on OEM Revision G diverter now.
zerrchh
« Reply #28 on: November 28, 2015, 05:17:12 pm »
Would be awesome man! I'm thinking of just trimming the edge of the plastic myself. There shouldn't be a big difference between n75 valves. I'm sure the one they use is stock besides the groove.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #29 on: December 13, 2015, 06:00:28 pm »
There was one on ebay for £50 brand new delivered with everything two weeks ago.
