Author Topic: Hurdy's Polo GTI..time for a new project!!  (Read 280548 times)
Offline Janner_Sy
  • -Receive: 113
Re: Hurdy's Polo GTI..time for a new project!!
« Reply #480 on: December 21, 2011, 03:13:36 pm »
« Reply #481 on: December 21, 2011, 03:16:18 pm »
« Reply #482 on: December 21, 2011, 03:16:51 pm »
Do you loose the supercharger as I suppose it becomes irrelevant if you go bigger turbo?
Offline Janner_Sy
  • -Receive: 113
« Reply #483 on: December 21, 2011, 03:26:10 pm »
Supercharger only operates upto 3500rpm before it disengages so it'll still be used and will help spool the turbo faster cancelling any extra lag you might expect with a larger turbo
« Reply #484 on: December 21, 2011, 03:27:21 pm »
I.e. it will be rapid  :laugh:
« Reply #485 on: December 21, 2011, 03:30:09 pm »
 :evilgrin: :driver: :evilgrin:
Offline Janner_Sy
  • -Receive: 113
« Reply #486 on: December 21, 2011, 03:36:49 pm »
BUT they say it'll only flow 270hp with all the bolts ons.
So your still 30hp shy of the 300hp target.  That said thats only looking at peak hp. Gains in the midrange might be immense.
Wander if ben will still want to do dsg development if I change tuner  :surprised:
« Reply #487 on: December 21, 2011, 03:39:36 pm »
Not what Supersi says  :evilgrin:
Offline Janner_Sy
  • -Receive: 113
« Reply #488 on: December 21, 2011, 03:45:06 pm »
Course it is, he's trying to sell you a turbo,he'll say anything to take some dollars off you.  He said 270hp in his sales post, if more was available or likely he'd have said in his OP.
Ever the pessimist  :laugh:
Quote from: supersi;134743
LOBA Motorsports GmbH
LO270 turbocharger
state-of-the-art “Extended Tip” compressor wheel
5-axis CNC re-profiled compressor housing and backplate
5-axis CNC re-profiled turbine housing
special clipped turbine wheel
optimized clearances
modified actuator
uprated bearing
precision balancing of individual components and CHRA
Depending on engine management settings, engine condition and other components utilized this turbo is capable of producing 270 PS
« Last Edit: December 21, 2011, 03:48:40 pm by Janner_Sy »
« Reply #489 on: December 21, 2011, 03:52:25 pm »
Not with my component list  :evilgrin:
Offline Janner_Sy
  • -Receive: 113
« Reply #490 on: December 21, 2011, 04:35:15 pm »
Look forward to the results.  Baring the WMI you now have everything either fitted or ordered to go ahead with the build dont you? Go forth and be the guinea pig john, I shall follow you up the road abit later
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #491 on: December 21, 2011, 04:50:26 pm »
I cant see why you would need any more power with this John. As it is, it sounds like the perfect combination of tractable power and grip levels and power to weight. Drag strips are boring, and thats all it will be good for it you just go for immense power.
#1493
Offline Janner_Sy
  • -Receive: 113
« Reply #492 on: December 21, 2011, 05:11:05 pm »
There's alot of truth in that
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #493 on: December 22, 2011, 04:40:44 pm »
I think John should stop chasing numbers over winter, wait till spring then take it for a blast around a track. If it still feels too slow, or like it can handle more power, then go for it. But personally, i think any more will ruin what looks to be an absolutely immense car.
#1493
Offline Janner_Sy
  • -Receive: 113
« Reply #494 on: December 22, 2011, 08:35:44 pm »
We've had a setback with the hybrid.  Looks like its not an option now with revo who don't want to develop past stage 2 anymore
