Author Topic: Hurdy's Polo GTI..time for a new project!!  (Read 288532 times)
Re: Hurdy's Polo GTI..time for a new project!!
« Reply #660 on: February 12, 2012, 12:04:44 am »
Comparison between a stock ed30 and mine. Pretty similar outputs across the range. Where the torque /bhp crosses over, mine has about 5bhp/lbft more.
ED30
Mine
Offline Janner_Sy
  • -Receive: 113
« Reply #661 on: February 12, 2012, 12:06:57 am »
That is mega similar, and also proves that power isnt everything, as yours would muller a stock ed30.  The joys of weighing 300kg less
« Reply #662 on: February 12, 2012, 12:11:54 am »
Pretty similar on a roll from 80mph up to 120mph - especially if the "heavy silver Pirelli" is going downhill to give it a weight advantage :innocent:
on the flat it does win against a "heavy silver Pirelli" and pulls on it even over 100mph  :evilgrin:  :popcornsoda: :popcornsoda:  *hides behind seat from Greeners* :wink:
Offline Janner_Sy
  • -Receive: 113
« Reply #663 on: February 12, 2012, 12:22:38 am »
I thought you said you were pulling on a stage 2 Cupra?  What power is the pirelli running? Id have thought you would have nailed a stock pirelli
« Reply #664 on: February 12, 2012, 12:27:44 am »
The run against the STAGE 2 Cupra was a low speed roll start from 20mph to around 90mph. Easy win with the weight advantage.
The run against the STOCK Pirelli was starting at 80+mph up to 120mph - different power band and weight isn't as much of a factor.  :happy2:
Offline Janner_Sy
  • -Receive: 113
« Reply #665 on: February 12, 2012, 12:29:29 am »
fair point.   :happy2:
« Reply #666 on: February 12, 2012, 06:55:12 pm »
 :innocent:
Pah 80! more like 60-70!  :innocent:
 :evilgrin:
« Reply #667 on: February 12, 2012, 07:59:57 pm »
:innocent:
 :evilgrin:
You've never seen 60mph on any "private" motorway :P
Offline Sunglasses Ron
« Reply #668 on: February 13, 2012, 03:52:03 pm »
Since when have Ed30/Pirelli's weighed nearly 1500kgs?!?!?  :confused: Unless of course John has got the Polo down to 1050kgs..?
« Last Edit: February 13, 2012, 03:53:47 pm by Sunglasses Ron »
« Reply #669 on: February 13, 2012, 04:13:48 pm »
Mine is 1150kg at the moment, but that is about 1/4 ton lighter than a 5dr DSG ED30/Pirelli. Soon should be lighter though! :wink:
« Reply #670 on: February 13, 2012, 04:27:06 pm »
My ED30 weighed in at 1356kgs (on the nose) when weighed on corner scales @ the 30-130 day in 2009 and 2011. That was with 1/4 of a tank of motion lotion and the usual odds and sods in the car.
Be interesting to see what the Polo weighs on the same scales John.. Getting close now..  :party:
What route are you taking by the way? If you come down the A17 you can meet up with our convoy  :happy2: There will be a Stage 2+ manual S3 you can give chase to as well..  :driver:
« Last Edit: February 13, 2012, 04:28:56 pm by Sunglasses Ron »
« Reply #671 on: February 13, 2012, 07:41:39 pm »
Not even thought about a route yet. I'll have my plate full just keeping up with the two cars I'm coming down with!!
Turbo, intercooler and maps should be sorted by then (fingers crossed), so a little more top end is always welcome. :jumping:
1356kg in a 3dr DSG is about right as the unladen official weight for a 3dr dsg is 1376kg with a 90% full tank. A 5dr is 25 or 30kg heavier iirc. :smiley:
« Reply #672 on: February 13, 2012, 07:53:11 pm »
Little update...
It's looking like the power mods are hitting the torque limiter of the DSG, so I'm back to needing at least a torque de-limit, before I get some more urge from the car.
The wmi must be working as I used over half a bottle of it on the round trip to JKM.  :evilgrin:
Been out today, even though it was damp the car still managed a 1/4 mile in 14.1 at 103.5mph and that was off a 5.8 second 0-60 as grip was at a premium. Hopefully I'll be able to get to the pod or York soon. :driver:
Offline Janner_Sy
  • -Receive: 113
« Reply #673 on: February 13, 2012, 08:02:41 pm »
Little update...
Whats making you say that?  iirc, it shows up in VCDS if it hits a limiter.  What is REVOs take on this, can they not bypass it?
Kev@ Jabba said that my DSG had showed 3 flashes on its ECU when he was given the car so i think shark had fiddled with the torque limiter somehow, like they did on DomTs ed30 when his DSG was limiting torque.
« Reply #674 on: February 13, 2012, 08:26:28 pm »
Little update...
I've spoken to Carl at Revo and he said do a DSG reset and re-calibration. Not had chance to do it yet, but I want to put the car on Statller's dyno first to see what is happening.
I may give Shark a call if my map is being limited by the DSG limiter. Maybe they can lift the limiter for me?
When you look at my JKM dyno the torque rises smoothly to 2600rpm and swiftly tops out and then wavers until it gets to 4900rpm when it goes smooth again as it tails off. Just seems strange that the torque chops off at that level? :confused:
