Author Topic: Cruise Control Problem  (Read 12784 times)
Offline redgem
« on: October 09, 2011, 02:12:25 pm »
I have had cruise control stalk fitted and coded the green speedo symbol lights up in the dash but the speed does not hold and + - buttons just do nothing?Lookers VW of Teeside have checked it and changed the stalk coded it and it still does not work.They checked with VW technical department but they are now saying they need to open the ECU? Any ideas?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Cruise Control Problem
« Reply #1 on: October 09, 2011, 02:16:58 pm »
what year is it?
have you a scan of your car
Cluster and Key coding
Location Great Yarmouth
Offline sundaydriver
« Reply #2 on: October 09, 2011, 02:25:32 pm »
Lookers Teeside hav'nt got a clue. I asked them to code my sat nav so it displays on the MFD and they told me they had to run a wire from the sat nav to the instrument cluster! :stupid: so i would'nt take any notice of them to be honest.
« Reply #3 on: October 09, 2011, 02:29:36 pm »
As Eddie says--get it scanned or get in contact with Darron who will sort it for you
Offline Scousus maximus
« Reply #4 on: October 09, 2011, 07:30:34 pm »
I'm in Stockton with VCDS if that's any good. I can scan but not much else! :ashamed:
Regards,
John
Offline mortygttdi
  • -Receive: 146
« Reply #5 on: October 09, 2011, 09:59:09 pm »
George speak to John(Scousus Maximus) and get your car scanned then Ill have a look at the scan for you :happy2: I think John with my help could sort this easily enough
Darren
Offline redgem
« Reply #6 on: October 10, 2011, 10:11:18 am »
VW lookers said no faults where showing???The car is 2007 dsg gti.
« Last Edit: October 10, 2011, 10:13:05 am by redgem »
Offline mortygttdi
  • -Receive: 146
« Reply #7 on: October 10, 2011, 04:25:15 pm »
We need to check if the engine module and steering module has been coded properly?
Darren
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #8 on: October 10, 2011, 05:57:22 pm »
get a scan done by the member that is near you, and post it up here
« Reply #9 on: October 10, 2011, 07:23:46 pm »
I'm not sure if this is posting ok but here goes. Did a first scan and got the following.
Then cleared the faults and did a test run, still no good even after a scan with no faults showing.The "intermittent" at address 16 looks dodgy to my untrained eye.
Regards,
John
ps I know my VCDS is out of date but I didn't want to update it until I did this scan so I knew I was working with a proven version.
Monday,10,October,2011,18:02:14:18648
VCDS Version: Release 10.6.4 (x64)
Data version: 20110418
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 76
VIN: WVWZZZ1KZ7W   Mileage: 40980km/25463miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 J    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0030
   Revision: 5BH16---    Serial number: VWZ7Z0G8113939
   Coding: 040300031C070160
   Shop #: WSC 78136 665 46858
   VCID: 2D5AB2C1CD81
1 Fault Found:
005699 - Please check DTC Memory of Electric Load Controller
               P1643 - 001 - Upper Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 0
                    Fault Frequency: 3
                    Mileage: 40831 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:39:09
             Freeze Frame:
                    RPM: 1681 /min
                    Load: 25.9 %
                    Speed: 68.0 km/h
                    Temperature: 92.0°C
                    Temperature: 16.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 14.351 V
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 02E-300-0xx.lbl
   Part No SW: 02E 300 043 Q    HW: 02E 927 770 AE
   Component: GSG DSG         082 1305
   Revision: 09808020    Serial number: 00000803250852
   Coding: 0000020
   Shop #: WSC 00770 210 105474
   VCID: 224051FD845F
No fault code found.
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
   Component: ESP FRONT MK60      0101
   Revision: 00H11001
   Coding: 0004738
   Shop #: WSC 01279 785 00200
   VCID: 73EE64B96B25
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1K0 907 044 BM    HW: 1K0 907 044 BM
   Component: ClimatronicPQ35 110 1010
   Revision: 00110021    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 73EE64B96B25
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000006975209
   Coding: E78F0F2700041500471400001400000000087F075C0001
   Shop #: WSC 00000 785 00200
   VCID: 6CDC7FC5361B
   Part No: 1K2 955 119 E
   Component: Wischer 190407 021  0501
   Coding: 00038805
   Shop #: WSC 00000
   Part No: 1K0 955 559 AB
   Component: RLS     200407 020  0105
   Coding: 00208933
   Shop #: WSC 00000
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: 38 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD165V28
   Coding: 0013112
   Shop #: WSC 01269 785 00200
   VCID: 3D7A82811DE1
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Component: J0527           638 0071
   Coding: 0012142
   VCID: 8102BE71A199
   Part No: XXXXXXXXXXX
   Component: E0221           002 0010
1 Fault Found:
00895 - Cruise Control Switch (E45)
            014 - Defective - Intermittent
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1K6 920 973     HW: 1K6 920 973
   Component: KOMBIINSTRUMENT VDD 1610
   Revision: V0003000    Serial number: VWZ7Z0G8113939
   Coding: 0007403
   Shop #: WSC 00675 210 62469
   VCID: F0E4EBB59A33
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 090407F1001038
   Coding: 7F0F074007000001
   VCID: 2F66A8C9C78D
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 1610
   VCID: F0E4EBB59A33
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1K0 959 701 N    HW: 1K0 959 701 N
   Component: Tuer-SG         005 0982
   Coding: 0000566
   VCID: 3972969109C9
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.074 H07 1806
   Shop #: WSC 00675 210 86472
   VCID: 356A9AA125D1
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0204
   Revision: 00020000    Serial number: 00000000000000
   Coding: 819002085103087F2D0484057008DAC690B800
   VCID: 830EB479BB85
   Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Part No: 1K0 951 178 A
   Component: Neigungssensor  003 0203
   Component: Innenraumueberw.003 0203
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 1K0 959 702 N    HW: 1K0 959 702 N
   Coding: 0000822
   VCID: 3A70899D0CCF
1 Fault Found:
00097 - Front Passengers Central Locking (Safe) Motor (V162)
            012 - Electrical Fault in Circuit - Intermittent
Address 55: Xenon Range        Labels: 1T0-907-357.lbl
   Part No: 1T0 907 357
   Component: Dynamische LWR      0003
   Coding: 0000003
   VCID: F4ECE7A5EE2B
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 1K0 035 186 T    HW: 1K0 035 186 T
   Component: Radio BVX       034 0046
   Revision: 00034000    Serial number: VWZ1Z2G4736237
   Coding: 0040400
   VCID: 377690A93FDD
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1K0 919 283 A
   Component: 22 Einparkhilfe     0101
   VCID: 2D5AB2C1CD81
Offline mortygttdi
  • -Receive: 146
« Reply #10 on: October 11, 2011, 06:02:18 am »
The steering wheel is not coded for cruise control if you ask John to go into the steering wheel and change 0012142 to 0013142 then the faults in the engine and the steering controller will delete themselves and you will have cruise working :happy2:
Also the fault on the engine module is only there because of the fault that is in the steering module once that is sorted then the engine fault will go.
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 3
                    Mileage: 40831 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:39:09
Darren
« Last Edit: October 11, 2011, 06:54:02 am by mortygttdi »
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #11 on: October 11, 2011, 06:33:09 am »
Darren
Changing the 2 to a 3  will change the mute button to a voice control control button.
when I had a mk5 mfsw in my car I had 0002022 and my cruise worked
try and check the measuring blocks to see if the stalk is ok and the engine
Offline mortygttdi
  • -Receive: 146
« Reply #12 on: October 11, 2011, 06:43:59 am »
Well this is the coding for the steering wheel
0xx?xxx: Steering Wheel
0 = Steering Wheel without Multifunction
1 = 3-Spoke Steering Wheel without Multifunction
2 = 3/4-Spoke Steering Wheel with Multifunction without Cruise & Voice Control
3 = 3/4-Spoke Steering Wheel with Multifunction with Cruise & Voice Control
George try it and see if it works if not then you've not lost anything?
Darren
« Last Edit: October 11, 2011, 06:50:16 am by mortygttdi »
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #13 on: October 11, 2011, 06:55:39 am »
I know it is strange but I think that part only relates to the button function.
apart from my car I have also done a cruise and paddle shift on a 2005 gti dsg. The cruise worked fine
   Part No SW: 1K0 953 549 AK    HW: 1K0 953 549 AK
   Component: J0527           036 0070
   Coding: 0012122
   Shop #: WSC 12345 123 12345
when alan came round to try the gateway, I changed his coding as his mute button started the voice control.
Offline mortygttdi
  • -Receive: 146
« Reply #14 on: October 11, 2011, 07:07:26 am »
This is a scan from a similar reg car
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56
VIN: WVWZZZ1KZ7W******   Mileage: 55210km/34305miles
01-Engine -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
37-Navigation -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
   Part No SW: 1K0 907 115 L    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWZ7Z0F8218059
   Shop #: WSC 07097 500 00200
   VCID: 2F67FD9CC238
Readiness: 0110 0101
   Component: J0527           636 0070
   Coding: 0013122
   VCID: 8103EB24A42C
This is another
   Part No SW: 1K0 907 115 J    HW: 1K0 907 115 F
   Revision: --H14---    Serial number: VWZ7Z0F3600246
   Coding: 0403000318070160
   Shop #: WSC 00191 264 15243
   VCID: 2D5BE794CD63
   Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
   Component: J0527           034 0070
   Coding: 0003022
   Shop #: WSC 00675 210 71777
   VCID: 77F705FC7FBF
« Last Edit: October 11, 2011, 07:22:16 am by mortygttdi »
