Author Topic: Cruise Control Problem  (Read 12768 times)
Offline skard
  • -Receive: 245
Re: Cruise Control Problem
« Reply #30 on: November 01, 2011, 05:37:31 pm »
My car came with cruise from the factory with the midline F module.
When I got the highline AQ module there was no problem with it working still, although I have a manual.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #31 on: November 01, 2011, 07:05:21 pm »
you might have a working AQ
Ross-tech lists that a BC can't have Cruise retrofitted
I have had 1 work and 1 not work
back on topic go for a BK controller
Cluster and Key coding
Location Great Yarmouth
MPS
Offline redgem
« Reply #33 on: November 02, 2011, 01:03:14 pm »
Thanks again John for scanning my car.So I`v read the replies but still not sure if its suppose to work or not?Ross tech graph says the AQ module supports cruise control but it seems like some people have had to change their control module?Thanks for the replies. :confused:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #34 on: November 02, 2011, 05:46:25 pm »
It could have been damaged before or during installation. Could have a Bug in the controller.
Ross-tech lists a BC won't work with cruise. I had one which worked and another which didn't.
Offline vwrascal
« Reply #35 on: November 02, 2011, 06:56:16 pm »
Was that mine that worked?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #36 on: November 02, 2011, 07:27:27 pm »
yes :happy2:
Offline redgem
« Reply #37 on: November 04, 2011, 09:36:45 pm »
I think we have come to the end on this looks like I need a steering control module anyone any ideas where I might get one?.I`d just like to say a big thank you to everyone for their help.
                      George :happy2:
MPS
« Reply #38 on: November 04, 2011, 09:49:24 pm »
                      George :happy2:
Loads on ebay! Up to you to find a compatible one though, the link I posted to the ross-tech chart might help you with that.
http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p4712.m570.l1313&_nkw=1K0-953-549&_sacat=See-All-Categories
Offline ahadmehmood
« Reply #39 on: November 17, 2013, 12:54:50 pm »
hi im having a similar problem if somebody can help this is my log
Thursday,14,November,2013,19:01:49:51843
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: VSSZZZ1PZ6R086566   License Plate:
Mileage: 141030km-87631mi   Repair Order: MO's 2006 Seat Leon 2.0TDI
Chassis Type: 1P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56
VIN: VSSZZZ1PZ6R086566   Mileage: 141030km/87631miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: Cannot be reached 1100
56-Radio -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKD.lbl
   Part No SW: 03G 906 021 LL    HW: 03G 906 021 LL
   Component: R4 2,0L EDC G000SG  9185
   Revision: --H03---    Serial number: SEZ7Z0F3473219
   Coding: 0050072
   Shop #: WSC 12345 123 45678
   VCID: 74E187231771ACBE80B-8021
2 Faults Found:
001384 - Cruise Control Switch (E45)
               P0568 - 008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 141037 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:48:31
             Freeze Frame:
                    RPM: 798 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.21 V
                    Bin. Bits: 11001100
                    Bin. Bits: 00000000
                    (no units): 0.0
005784 - Please Check DTC Memory of Steering Wheel Electronics
               P1698 - 001 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 141037 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:48:31
             Freeze Frame:
                    RPM: 798 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.21 V
                    Bin. Bits: 11001100
                    Bin. Bits: 00000000
                    (no units): 0.0
Readiness: 0 0 0 0 1
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0000641
   Shop #: WSC 06441 785 00200
   VCID: 3F8B180F6EB73FE6AD9-806A
No fault code found.
Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
   Part No SW: 5P0 820 047 M    HW: 5P0 820 047 M
   Component: Climatic PQ35   014 0606
   Revision: 00014014    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 377B702F468707A6659-8062
2 Faults Found:
01296 - Sensor for Vent Temperature; Center (G191)
            007 - Short to Ground
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000003969246
   Coding: A1880F3F00041000001D00000000000000007F075C
   Shop #: WSC 00008 210 45725
   VCID: 2B535C5F8ACFB346111-807E
   Subsystem 1 - Part No: 1P0 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SE350  012  0403
   Coding: 00056272
   Shop #: WSC 00008
2 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 6
                    Mileage: 141037 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 13.95 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
00979 - Lamp for Low Beam; Right (M31)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 6
                    Mileage: 141037 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 13.95 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 3C0-909-605.lbl
   Part No SW: 3C0 909 605 L    HW: 3C0 909 605 L
   Component: R4 AIRBAG VW8   030 2522
   Revision: 12030000    Serial number: 003B0PDCNUPD
   Coding: 0021044
   Shop #: WSC 04941 785 00200
   VCID: 2F6B484FBED7CF663D9-807A
   Subsystem 1 - Serial number: 6332MSME0E405F49
   Subsystem 2 - Serial number: 6342MSME0E340A72
   Subsystem 3 - Serial number: 6351HTS64IKMM563
   Subsystem 4 - Serial number: 6361HTS63IKAIAT2
   Subsystem 5 - Serial number: 00000000000000000
   Subsystem 6 - Serial number: 00000000000000000
1 Fault Found:
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
            001 - Upper Limit Exceeded - MIL ON
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
   Component: J0527           056 0111
   Coding: 0000534
   Shop #: WSC 12345 123 12345
   VCID: 7AFDA91B3515DACEDA7-802F
   Subsystem 1 - Part No: 1P0 959 538 B
   Component: E221__MFL-TAP   H01 0100
   Coding: 00000226
   Shop #: WSC 00000
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1P0 920 941 A
   Component: KOMBIINSTRUMENT VO3 0724
   Coding: 0002401
   Shop #: WSC 00046 476 88215
1 Fault Found:
01771 - Control Module for Headlight Range (J431)
            004 - No Signal/Communication
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 280010630681B3
   Coding: 7D0F0348072203
   VCID: 2A5D595B8535AA4EEA7-807F
1 Fault Found:
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 62
                    Reset counter: 6
                    Mileage: 140726 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:27:36
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VO3 0724
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 C    HW: 1T0 035 680 B
   Component: RNS-MID       H11 1300
   Revision: AB001001    Serial number: VWZ6Z7J8273164
   Coding: 04000400040000120020
   Shop #: WSC 00020 790 12345
   VCID: 2E55554B79DDC66E36F-807B
2 Faults Found:
03138 - Input AUX IN
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 46
                    Mileage: 140726 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:27:51
01299 - Diagnostic Interface for Data Bus (J533)
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 252
                    Mileage: 140726 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:27:52
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
   Part No: 1T0 959 701 B
   Component: Tuer-SG         024 2352
   Coding: 0000688
   VCID: 36657D2B418DFEAE7EF-8063
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   VCID: 3461472357F1ECBE40B-8061
1 Fault Found:
00778 - Steering Angle Sensor (G85)
            000 - -
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Component:    KSG              0401
   Coding: 19C000BC09000505485B863004CC
   VCID: 79FFB6173013D1D6D3D-802C
   Subsystem 1 - Component:   Sounder No Answer
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE No Answer
2 Faults Found:
01135 - Interior Monitoring Sensors
01134 - Alarm Horn (H12)
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
   Part No: 1T0 959 702 B
   Coding: 0000688
Address 55: Xenon Range
Cannot be reached
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 46
                    Mileage: 140726 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:27:51
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 252
                    Mileage: 140726 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:27:52
End   ---------------------------------------------------------------------
