Poll
Do you run a Forge Spacer?
Yes, love it.
2 (18.2%)
Yes, but may remove sounds chavvy
3 (27.3%)
Yes, but removed due to issues it caused.
1 (9.1%)
No, have concerns about them.
0 (0%)
No, too chavvy for me.
5 (45.5%)
Total Members Voted: 11
Voting closed: October 21, 2011, 12:42:55 pm
Author Topic: Forge Spacer  (Read 2114 times)
Offline E30Dom
  • -Given: 42
  • -Receive: 76
Forge Spacer
« on: October 11, 2011, 12:42:55 pm »
Hi Guys,
Just gauging everyones thoughts on the Forge Spacer. I have one ready for fit, can't find any detrimental reasons not too, just a noise maker and I like/want the tissschh noise, one reason for having a turbo...
But understand they are a bit chavvy for some, just wanted peoples opinions...
Thanks,
Dom
p.s. it won;t sway me either way, it will be fitted and I will make up own mind...
Diesel Daily Hack.
Offline Jaywoo-GTI
  • -Given: 38
Re: Forge Spacer
« Reply #1 on: October 11, 2011, 02:19:18 pm »
I have got one on mine, Caused no problems but it dumps all the time, will be removing it when i fit my downpipe as i get a nicer dump sound through my intake.
Offline big al
Re: Forge Spacer
« Reply #2 on: October 11, 2011, 03:03:31 pm »
Go for the twintake instead, nice noise, and you can tell it is actually doing something.
If you want silly noises in your car then get a Mr T talking keyring  :signLOL:
Offline johnboy07
Re: Forge Spacer
« Reply #3 on: October 11, 2011, 03:07:12 pm »
im thinking about getting one too. i love the sound and always have and for me apart from the power its why i love turbo cars. Theres alot of people on here who are really against them but its each to there own and personally feel everyone is entitled to there own ideas thoughts and purchases so go for it mate. Let me know what you think once its on  :happy2:
Stage 2+ 280.4 bhp ITG, Revo Stage 2+, decat, hpfp, THS intercooler, THS engine mounts, Pcv revamp, sportline springs, rs4 fuel valve, DS2500 pads and brembo discs, braided lines, ATE super blue brake fluid and more to come
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: Forge Spacer
« Reply #4 on: October 11, 2011, 03:09:36 pm »
i've read somewhere that the engine is designed to recirculate the dumped gases, and that the BOV hinders performance? until this is refuted by someone i don't think i'll be getting one. i do like the sound tho. with a DV relocation kit and the adaptive BOV i'd definitely consider one (so that i can switch it off easily for motorwasy journeys and the like and get maximum pose factor the rest of the time)
PLANS: Stage 2+
Offline E30Dom
  • -Given: 42
  • -Receive: 76
Re: Forge Spacer
« Reply #5 on: October 11, 2011, 03:53:09 pm »
From mike@forgemotorsport on Vortex...
Completely irrelevant to someone's personal preference concerning sound or the engine management system's requirements for valve function.....
.... whether the air is vented to the atmosphere or recirculated is completely irrelevant to spool or any amount of “lag” supposedly created.
A valve exists in a turbocharged system as a failsafe against such a thing altogether.
"Lag" would only be created if there were no valve in place at all, and the residual charge air inside the intercooler piping "backed up" into the compressor wheel at throttle lift slowing it down.
Whether an atmospheric or a recirculating valve is used to discharge the residual pressure, either valve is still able to vent at throttle lift allowing the compressor wheel to maintain it's rate of speed, thus preventing any reversion of pressure and inducing any “lag” or having an affect on spool.
The discharged air being recirculated back into the intake side of the system will have absolutely ZERO affect on spool as opposed to an atmospheric setup.
The intake side of the system is under constant vacuum vs. actual atmospheric pressure (altitude), so the only arguement that could be made is that the vacuum effect acting on the discharged/vented air somehow keeps the turbo spinning faster than if it's vented to the atmosphere.
There is ZERO empirical evidence that one setup is more beneficial or detrimental than another in relation to compressor wheel speed.
If the use of an atmospheric valve is possible without any negative side effects concerning the engine management system of the application, as is the case on this vehicle, then it becomes purely a matter of personal preference.
Diesel Daily Hack.
Offline Jaywoo-GTI
  • -Given: 38
Re: Forge Spacer
« Reply #6 on: October 11, 2011, 03:59:13 pm »
Exactly, the mk5 DV valve is simply a bypass valve not a recirc valve like on 1.8t 20v engines where the airflow is re-monitored after the DV.
Hence the reason why the DV on a MK5 is electronically control and not vacuum controlled.
« Last Edit: October 11, 2011, 04:07:47 pm by Jaywoo-GTI »
Offline E30Dom
  • -Given: 42
  • -Receive: 76
Re: Forge Spacer
« Reply #7 on: October 11, 2011, 05:10:22 pm »
^^^ so it's perfectly safe...
Only thing I worry about is it drawing contaminants through the holes(and I have a K04 when it's placed at front!)
Diesel Daily Hack.
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: Forge Spacer
« Reply #8 on: October 11, 2011, 05:16:23 pm »
great, more to add to my shopping list. thanks   :rolleye:
PLANS: Stage 2+
Offline johnboy07
Re: Forge Spacer
« Reply #9 on: October 11, 2011, 05:40:43 pm »
haha i just bought one to give it a go. for £25 even if i dont like it, im not going to lose sleep over the money  :driver:
Offline JackG
  • -Given: 33
  • -Receive: 31
    • Distinct Detailing
Re: Forge Spacer
« Reply #10 on: October 11, 2011, 10:14:52 pm »
I've got one on my ed30 and love it  :signLOL: doesn't sound chavy to me as it makes a massive chatter! Doesn't sound like the mk4 1.8T ones wich just go psssstttt, sounds ace and gets pepole looking, even make pepole jump  :signLOL:
Got mine from the forge shop on eBay for £25 and it's the best mod I've bought for the money  :drinking:
www.distinctdetailing.co.uk
Offline GarethB
Re: Forge Spacer
« Reply #11 on: October 12, 2011, 08:49:13 am »
Does it work with the oem Rev D DV? - I'm sure that I read somewhere that it wasn't compatible.
Offline Jaywoo-GTI
  • -Given: 38
Re: Forge Spacer
« Reply #12 on: October 12, 2011, 09:35:03 am »
I brought mine off german ebay for £15, was worth trying out at that price.
Offline E30Dom
  • -Given: 42
  • -Receive: 76
Re: Forge Spacer
« Reply #13 on: October 12, 2011, 12:32:56 pm »
There is aspecific one for the ed30/s3...
Diesel Daily Hack.
