November 24, 2024, 10:39:14 am
All Things Mk5
Sat Nav and Car Audio
Does any CanBus gateway after version 'L' work?
Topic: Does any CanBus gateway after version 'L' work? (Read 1989 times)
jedi-knight83
Just look at my post count
-Given: 12
-Receive: 41
October 12, 2011, 06:32:42 pm »
Well reading into it more... so my battery doesn't die I need to upgrade my canbus gateway from whats currently in the car which is 'F' to 'L' or higher...
On this site is just says 'L' or higher and states a few options but my question is... does any letter after 'L' work just as well as the ones stated?
http://www.my-gti.com/1101/upgrading-2nd-generation-radios-rcd-300-rcd-500-to-3rd-generation-rcd-210-rcd-310-rns-310-rcd-510-power-drain-issue
Golf GTI DSG "ED30 Tribute"
- RTech: 254bhp / 323lbft | MK6 GTI DSG S.Wheel | MK6 GTI speedo | MK6 climate | RCD510DAB | Bluetooth | Milltek Cat back | H&R Springs & Rear ARB | WALK | 19" BBS CH | MK7R 340mm brakes -
INFO
stealthwolf
-Given: 306
-Receive: 291
ED30 No.1412
Re: Does any CanBus gateway after version 'L' work?
Reply #1 on:
October 12, 2011, 08:12:13 pm »
In theory, yes. In practice, you might struggle to find earlier canbuses.
The
GTI
isn't just a machine. It's very much a living, breathing thing.
Eddie-NL
Trader - 2014
-Given: 0
-Receive: 298
My Ride:
Reply #2 on:
October 12, 2011, 08:31:14 pm »
L and above
AA - AF
Newer 7N0 versions after that
if you need one I have some in the for sale section
Genuine VCDS VAG-COM HEX-USB + Genuine Vag Commander + Genuine VAG Tacho + Genuine VAG CAN PRO + RNS Manager for Video in Motion and New Pin Code for RNS510
Cluster and Key coding
Location Great Yarmouth
jedi-knight83
-Given: 12
-Receive: 41
Reply #3 on:
October 12, 2011, 09:08:51 pm »
Quote from: Eddie-NL on October 12, 2011, 08:31:14 pm
L and above
AA - AF
so would 'P' work?
Where is your link?
I dont 'want' one but i 'need' one it seems
INFO
Eddie-NL
Trader - 2014
-Given: 0
-Receive: 298
My Ride:
Reply #4 on:
October 12, 2011, 09:13:38 pm »
have a look in the for sale section, I have just done a bump. Don't want to post links to classified in the general areas.
Timvgti
Always Involved
-Given: 0
-Receive: 5
Reply #5 on:
October 17, 2011, 02:04:16 pm »
Do you need to update the gateway because your RNS 510 drains the battery?
If so, you can also install modified new firmwares!
I have a modified FW2760 firmware with an old standard E version gateway (2005 EU GTI). No battery drain at all.
alexperkins
-Given: 7
-Receive: 99
Reply #6 on:
October 18, 2011, 07:52:50 am »
Yes.
Its important to note that the modified firmware doesn't always work though and battery drain can still happen
Timvgti
Always Involved
-Given: 0
-Receive: 5
Reply #7 on:
October 18, 2011, 08:11:23 am »
Correct! I think you also need a original B version for it, which I have.
All Things Mk5
