Author Topic: Anyone used this on the dreaded inlet valve problem?  (Read 5709 times)
Offline Jaywoo-GTI
  • -Given: 38
« on: October 13, 2011, 09:38:05 am »
Found this on Halfords site and seems to work very similar to the 3M stuff from the US (detailed in the other thread)
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_185422_langId_-1_categoryId_255221
Whats everyone's opinion on this and do they think it will help clear some of the deposits off the valves if spray into the inlet manifold whilst the car is running?
Offline johnboy07
Re: Anyone used this on the dreaded inlet valve problem?
« Reply #1 on: October 13, 2011, 12:02:02 pm »
id also be interested to know peoples views on this as always contemplated trying it.  :popcornsoda:
Stage 2+ 280.4 bhp ITG, Revo Stage 2+, decat, hpfp, THS intercooler, THS engine mounts, Pcv revamp, sportline springs, rs4 fuel valve, DS2500 pads and brembo discs, braided lines, ATE super blue brake fluid and more to come
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #2 on: October 13, 2011, 12:19:41 pm »
My local halfords had something similar produced by Wynn's? - IIRC this is the stuff VW have on the TSB  :confused:
Offline Jaywoo-GTI
  • -Given: 38
« Reply #3 on: October 14, 2011, 09:01:04 am »
Cant find anythin similar on the Wynn's website? You got any more details?
And sorry to sound stupid but what is a TSB?
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #4 on: October 14, 2011, 09:37:33 am »
^^^ Technical Service Bulletin maybe? stab in the dark
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #5 on: October 14, 2011, 11:48:06 am »
PLANS: Stage 2+
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #6 on: October 14, 2011, 02:31:24 pm »
Its called "Direct Injection Power 3" Inlet Valve Cleaner - you spray it in the intake (or through the PCV inlet) and it cleans the valves. Have a look on ebay mate :happy2:
Its made for Direct Injection engines like ours - I think the Cupra Boys are using it
Offline Jaywoo-GTI
  • -Given: 38
« Reply #7 on: October 14, 2011, 02:38:41 pm »
Awesome cheers gray i will have a look now.
Offline Jaywoo-GTI
  • -Given: 38
« Reply #8 on: October 14, 2011, 02:43:58 pm »
Found some perfect info on  it here, Perfect for tfsi engines.
[pdf]http://www.wynns.net/product_files/direct%20injection%20power%203%20(aerosol)%2023079.pdf[/pdf]
Also found this interesting
Quote from: jon-tfsi;2693446
The best way to get these products onto the valves on a TFSI engine is directly into the intake manifold. I have tried it and works. You cant rev the engine though as if you get boost pressure the pipe will be blown out of the port. On the other end of the pipe is a football inflation needle which meters the flow of product (redex in this case). On tickover there is a vaccum which draws the redex into the manifold and over the valves.
« Last Edit: October 14, 2011, 02:53:45 pm by Jaywoo-GTI »
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #9 on: October 14, 2011, 08:25:22 pm »
Thanks for the thanks  :smiley:
That looks clever, not sure what that port is the redex is going into though?
I'd have used the PCV port on the right
Offline lee_
« Reply #10 on: October 14, 2011, 08:31:39 pm »
Can anyone confirm that this method of 'injecting' redex into the inlet manifold is successful?
Is that some sort of port in the middle of the manifold that they're injecting through?
Offline streetbeefGTI
« Reply #11 on: October 14, 2011, 08:40:43 pm »
this seems very promising might purchase this at the weekend as my car is on 120k now, but still going strong!  :wink:
Offline Jaywoo-GTI
  • -Given: 38
« Reply #12 on: October 15, 2011, 10:25:26 pm »
Just tried the above redex method tonight, There is a sensor directly above the throttle body that need to be taken out for the pipe to go in.
I used electrical tape to ensure a tight fit (and my son's football pump adaptor :P) to get the redex into the intake manifold,
Just remeber not to rev the car and once the car start to struggle pull the tube out of the redex,
So far results seem good, certainly no adverse effects. The car does not seem any better but didnt expect it to as it is just a maintainence procedure.
Only downside i have found is disconnecting the sensor pulled up a fault code but cleared on my Liquid 2 so easily fixed.
In all well worth a try as it can only help and only took me ten mins and the a good spirited drive to clear the car out afterwards.
Oh and another plus point is Redex is on offer for £2 at Asda at the moment. :happy2:
« Last Edit: October 15, 2011, 10:27:33 pm by Jaywoo-GTI »
Offline Jaywoo-GTI
  • -Given: 38
« Reply #13 on: October 26, 2011, 09:27:54 am »
Anyone else tried it yet, Seems to have worked well on my car and will be doing it every six months now.
Offline cupra_k1
« Reply #14 on: October 26, 2011, 12:19:06 pm »
I did this a few months back using the air temperature sensor port too. Just make sure you use a football pump adaptor to limit the flow. I can't say i 'noticed' any difference but i never checked the state of the inlet valves before or after the event. Be warned though, you may experience quite a bit of white smoke from the exhaust for a couple of miles afterwards  :laugh:
Also it is advisable to change your engine oil afterwards. Snowfoam is generally used over in the States, but it is not easy to get hold of over here.
